跳转到主内容
HP Pavilion DV5T-1000 Hard Drive Replacement
你所需要的
    • Make sure the laptop is turned off, and the power cable is removed.
    • Leaving the laptop turned on can cause damage to the hardware and any stored data.
  1. HP Pavilion DV5T-1000 Hard Drive Replacement: 步骤 2 中的图像 1,1
    • Turn the laptop over to access the backside of the computer.
    • Identify and confirm that the laptop is an HP Pavilion DV5T-1000.
  2. HP Pavilion DV5T-1000 Hard Drive Replacement: 步骤 3 中的图像 1,2 HP Pavilion DV5T-1000 Hard Drive Replacement: 步骤 3 中的图像 2,2
    • Slide the battery lock to the left, it's located just below the battery compartment.
    • Pull the battery up and out, to remove it from the battery compartment.
    • To prevent hardware damage, remove the battery before working on the laptop.
  3. HP Pavilion DV5T-1000 Hard Drive Replacement: 步骤 4 中的图像 1,1
    • Identify the hard drive compartment, located at the top left-hand frame of the laptop.
  4. HP Pavilion DV5T-1000 Hard Drive Replacement: 步骤 5 中的图像 1,1
    • In order to remove the hard drive compartment cover, first remove the two screws located on the panel, using a size 0 Phillips head screwdriver.
  5. HP Pavilion DV5T-1000 Hard Drive Replacement: 步骤 6 中的图像 1,1
    • Expose the hard drive by lifting the drive cover.
  6. HP Pavilion DV5T-1000 Hard Drive Replacement: 步骤 7 中的图像 1,1
    • In order to loosen the hard drive from the motherboard, tug gently on the black tabs located at both ends of the hard drive.
    • Be cautious when handling the cable that connects the hard drive to the computer's motherboard.
  7. HP Pavilion DV5T-1000 Hard Drive Replacement: 步骤 8 中的图像 1,2 HP Pavilion DV5T-1000 Hard Drive Replacement: 步骤 8 中的图像 2,2
    • Firmly hold both the black plug, and the hard drive itself to separate the drive from the cable.
  8. HP Pavilion DV5T-1000 Hard Drive Replacement: 步骤 9 中的图像 1,2 HP Pavilion DV5T-1000 Hard Drive Replacement: 步骤 9 中的图像 2,2
    • Remove the 4 screws using a size 0 Phillips head screwdriver.
    • Remove the metal from the perimeter of the hard drive.
结论
4等其他人完成本指南。
Josh Taimanglo
于09/21/15注册
147 声望
撰写一个指南
团队
Colorado Springs, Team 6-5, Mcmichael Fall 2015 Colorado Springs, Team 6-5, Mcmichael Fall 2015 的会员
UCCS-MCMICHAEL-F15S6G5
4 名成员
创作了1篇指南
一条评论
Help after replacing hard drive installation of windows
Bettyjean Serrano - 回复
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 10
过去 30 天: 38
总计 1,858
