跳转到主内容
加入维修社区 - 创建账户
HP Pavilion DV3 Hard Drive Replacement
你所需要的
  1. HP Pavilion DV3 Hard Drive Replacement, Battery: 步骤 1 中的图像 1,1
    • Step 1 – Battery: Locate the battery release slider on the bottom of the laptop and move it in the direction of the arrow to the unlock position.
    • The yellow highlighted edge of the battery should pop up slightly when the switch is moved
    询问修复机器人
  2. HP Pavilion DV3 Hard Drive Replacement: 步骤 2 中的图像 1,2 HP Pavilion DV3 Hard Drive Replacement: 步骤 2 中的图像 2,2
    • Step 2: Using the edge of the battery that has popped up, lift the battery out of the computer.
    询问修复机器人
  3. HP Pavilion DV3 Hard Drive Replacement, Hard Drive: 步骤 3 中的图像 1,1
    • Locate the screw for the hard drive cover (The cover has HP ProtectSmart written on it).
    • Remove the 3.5 mm diameter, 7 mm long screw with your Phillips PH1 screwdriver.
    • The screw will remain attached to the cover.
    询问修复机器人
  4. HP Pavilion DV3 Hard Drive Replacement: 步骤 4 中的图像 1,2 HP Pavilion DV3 Hard Drive Replacement: 步骤 4 中的图像 2,2
    • Grab the raised edge of the cover lift up. This will separate the cover from the laptop.
    • Put the cover and screw to the.
    • This will reveal the hard drive.
    询问修复机器人
  5. HP Pavilion DV3 Hard Drive Replacement: 步骤 5 中的图像 1,3 HP Pavilion DV3 Hard Drive Replacement: 步骤 5 中的图像 2,3 HP Pavilion DV3 Hard Drive Replacement: 步骤 5 中的图像 3,3
    • With your fingers, grab the clear tab.
    • Pull right first, and then upwards (towards you).
    • The hard drive should slide out of place and detach from the laptop.
    询问修复机器人
结论
5等其他人完成本指南。
团队
Cal Poly, Team 14-10, Forte Fall 2013 Cal Poly, Team 14-10, Forte Fall 2013 的会员
CPSU-FORTE-F13S14G10
4 名成员
创作了5篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 44
总计 5,340
