跳转到主内容
HP Pavilion DV2160BR Wifi Adapter Replacement
你所需要的
  1. HP Pavilion DV2160BR Wifi Adapter Replacement, Wifi Adapter: 步骤 1 中的图像 1,2 HP Pavilion DV2160BR Wifi Adapter Replacement, Wifi Adapter: 步骤 1 中的图像 2,2
    • Start with the bottom of the laptop facing up.
    • Locate the small panel under the battery, which houses the wifi adapter, and unscrew the one 5mm Phillips #0 screw holding the panel in place.
    • Remove the panel and set it aside.
    • Be careful not to snap the 2 tabs on the sides of the panel when pulling it out.
  2. HP Pavilion DV2160BR Wifi Adapter Replacement: 步骤 2 中的图像 1,2 HP Pavilion DV2160BR Wifi Adapter Replacement: 步骤 2 中的图像 2,2
    • Unscrew the two 3mm Phillips #0 screw which is located at the corners of the wifi adapter.
  3. HP Pavilion DV2160BR Wifi Adapter Replacement: 步骤 3 中的图像 1,2 HP Pavilion DV2160BR Wifi Adapter Replacement: 步骤 3 中的图像 2,2
    • Pull the 2 black wires with the gold pieces out of the wifi adapter.
    • The wifi adapter is now free to be removed.
    • When reconnecting the wires for re-installing the wifi adapter, make sure the gold ends are rotated correctly to be properly pushed back in.
结论
另外一个人完成了本指南。
Shannon
于04/11/13注册
55 声望
创作了6篇指南
团队
Cal Poly, Team 13-66, Johann Spring 2013 Cal Poly, Team 13-66, Johann Spring 2013 的会员
CPSU-JOHANN-S13S13G66
3 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 12
总计 533
