跳转到主内容
HP Pavilion DV2160BR Webcam Replacement
你所需要的
  1. HP Pavilion DV2160BR Webcam Replacement, Battery: 步骤 1 中的图像 1,1
    • Start with the bottom of the laptop facing up.
  2. HP Pavilion DV2160BR Webcam Replacement: 步骤 2 中的图像 1,2 HP Pavilion DV2160BR Webcam Replacement: 步骤 2 中的图像 2,2
    • Locate the battery compartment at the rear of the device.
    • There is a slider button located under the left side of the battery compartment. It is indicated by a battery symbol. Move the slider to the left and lift the battery out.
  3. HP Pavilion DV2160BR Webcam Replacement, Webcam: 步骤 3 中的图像 1,1
    • Flip over the laptop and open it.
  4. HP Pavilion DV2160BR Webcam Replacement: 步骤 4 中的图像 1,2 HP Pavilion DV2160BR Webcam Replacement: 步骤 4 中的图像 2,2
    • Remove the 6 rubber screw covers from the screen panel using the plastic opener tools by applying firm pressure to the edges.
    • The 4 screw covers on top are attached by an adhesive backing.
    • The 2 screw covers on the bottom are rubber plugs.
  5. HP Pavilion DV2160BR Webcam Replacement: 步骤 5 中的图像 1,1
    • Remove the 4 M2.5x4-Lg #0 Phillips screws from the top of the screen panel.
    • Remove the 2 M2.5x8-Lg #1 Phillips screws from the bottom of the screen panel.
  6. HP Pavilion DV2160BR Webcam Replacement: 步骤 6 中的图像 1,2 HP Pavilion DV2160BR Webcam Replacement: 步骤 6 中的图像 2,2
    • Slide a plastic opener tool along the outside edges of the front screen panel to start to separate it from the back screen panel.
    • You may need to apply some firm pressure to get it started.
    • Once it has started to separate, gently pull off the screen panel by working along the edge, and set it aside.
  7. HP Pavilion DV2160BR Webcam Replacement: 步骤 7 中的图像 1,1
    • Locate the screw on the left side of the cameras mounting bracket.
    • Remove the M2.5x4-Lg #0 Phillips screw
  8. HP Pavilion DV2160BR Webcam Replacement: 步骤 8 中的图像 1,1
    • Pull the camera from the back screen panel and rotate it so you are looking at the back.
    • Remove the 2 M2x3-Lg #00 Phillips screws and place the mounting bracket aside.
  9. HP Pavilion DV2160BR Webcam Replacement: 步骤 9 中的图像 1,1
    • Disconnect the cable on the right side of the camera board by pulling firmly on the connector.
结论
另外一个人完成了本指南。
团队
UMass Dartmouth, Team 6-5, Vijaybhaskar Spring 2014 UMass Dartmouth, Team 6-5, Vijaybhaskar Spring 2014 的会员
UMASSD-VIJAYBHASKAR-S14S6G5
3 名成员
创作了3篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 774
