跳转到主内容
HP Pavilion DV2160BR RAM Replacement
你所需要的
  1. HP Pavilion DV2160BR RAM Replacement, RAM: 步骤 1 中的图像 1,2 HP Pavilion DV2160BR RAM Replacement, RAM: 步骤 1 中的图像 2,2
    • Start with the bottom of the laptop facing up.
    • Locate the panel that is covering the RAM compartment.
    • Unscrew the two 5mm Phillips #0 screws that are securing the RAM compartment.
  2. HP Pavilion DV2160BR RAM Replacement: 步骤 2 中的图像 1,2 HP Pavilion DV2160BR RAM Replacement: 步骤 2 中的图像 2,2
    • Lift up the panel that is by the end that held the screws. Set it aside.
  3. HP Pavilion DV2160BR RAM Replacement: 步骤 3 中的图像 1,3 HP Pavilion DV2160BR RAM Replacement: 步骤 3 中的图像 2,3 HP Pavilion DV2160BR RAM Replacement: 步骤 3 中的图像 3,3
    • Using 2 prying tools, push the 2 buttons on the sides of one RAM module simultaneously, so that one side of the module pops up and out of the clips holding it down.
    • Grab the RAM module and carefully pull it straight out of its slot.
    • Repeat this step for the second RAM module, which is located just underneath the first RAM module.
结论
Shannon
于04/11/13注册
55 声望
创作了6篇指南
团队
Cal Poly, Team 13-66, Johann Spring 2013 Cal Poly, Team 13-66, Johann Spring 2013 的会员
CPSU-JOHANN-S13S13G66
3 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 6
总计 382
