跳转到主内容
HP Pavilion DV2160BR Inverter Replacement
你所需要的
  1. HP Pavilion DV2160BR Inverter Replacement, Inverter: 步骤 1 中的图像 1,1
    • Start with the laptop sitting up and open.
  2. HP Pavilion DV2160BR Inverter Replacement: 步骤 2 中的图像 1,3 HP Pavilion DV2160BR Inverter Replacement: 步骤 2 中的图像 2,3 HP Pavilion DV2160BR Inverter Replacement: 步骤 2 中的图像 3,3
    • Remove the 6 rubber screw covers and screws, found around the edge of the laptop screen, surrounded in red and blue.
    • Use the plastic opener tools to remove the screw covers. Just apply firm pressure to the edges to pop the screw covers out, they are attached with a light adhesive.
    • There are four 2.5mm X 4mm-L Phillips #0 screws along the top.
    • There are two 2.5mm X 8mm-L Phillips #1 screws along the bottom.
  3. HP Pavilion DV2160BR Inverter Replacement: 步骤 3 中的图像 1,2 HP Pavilion DV2160BR Inverter Replacement: 步骤 3 中的图像 2,2
    • Slide a plastic opener tool along the outside edges of the front screen panel, separating it from the screen. You may need to apply some firm pressure.
    • Once the panel is separated from the screen, gently pull it off and set it aside.
  4. HP Pavilion DV2160BR Inverter Replacement: 步骤 4 中的图像 1,2 HP Pavilion DV2160BR Inverter Replacement: 步骤 4 中的图像 2,2
    • The inverter is located underneath the screen.
    • Unscrew the two 5mm Phillips #0 screws holding it in place, one on each end of the inverter.
  5. HP Pavilion DV2160BR Inverter Replacement: 步骤 5 中的图像 1,2 HP Pavilion DV2160BR Inverter Replacement: 步骤 5 中的图像 2,2
    • Disconnect the grey LCD cable on the left side of the inverter by holding the inverter in place and pulling firmly on the connector.
    • Disconnect the backlight plug cable on the right side of the inverter by holding the inverter in place and pulling firmly on the connector.
  6. HP Pavilion DV2160BR Inverter Replacement: 步骤 6 中的图像 1,1
    • Remove the inverter from the device.
结论
3等其他人完成本指南。
Shannon
于04/11/13注册
55 声望
创作了6篇指南
团队
Cal Poly, Team 13-66, Johann Spring 2013 Cal Poly, Team 13-66, Johann Spring 2013 的会员
CPSU-JOHANN-S13S13G66
3 名成员
创作了6篇指南
一条评论
Thank you for enriching my knowledge.
Hope to meet you again.
ashique mahamud - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 19
总计 1,404
