跳转到主内容
HP Pavilion DV2160BR Hard Drive Replacement
你所需要的
  1. HP Pavilion DV2160BR Hard Drive Replacement, Hard Drive: 步骤 1 中的图像 1,2 HP Pavilion DV2160BR Hard Drive Replacement, Hard Drive: 步骤 1 中的图像 2,2
    • Start with the bottom of the laptop facing up.
    • Locate the panel covering the hard drive compartment.
    • Unscrew the two 5mm Phillips #0 screws.
  2. HP Pavilion DV2160BR Hard Drive Replacement: 步骤 2 中的图像 1,1
    • Lift up this external panel by the end with the screws and set it aside.
    • Be careful about the four plastic tabs holding the panel on the device.
  3. HP Pavilion DV2160BR Hard Drive Replacement: 步骤 3 中的图像 1,2 HP Pavilion DV2160BR Hard Drive Replacement: 步骤 3 中的图像 2,2
    • Locate the second plastic panel covering the hard drive.
    • Unscrew the two 4mm Phillips #0 screws holding it in.
  4. HP Pavilion DV2160BR Hard Drive Replacement: 步骤 4 中的图像 1,1
    • Lift up this internal panel using the plastic white tab and set it aside.
  5. HP Pavilion DV2160BR Hard Drive Replacement: 步骤 5 中的图像 1,3 HP Pavilion DV2160BR Hard Drive Replacement: 步骤 5 中的图像 2,3 HP Pavilion DV2160BR Hard Drive Replacement: 步骤 5 中的图像 3,3
    • Grab the end of the hard drive and pull it up to a vertical position.
    • Gently slide the Hard Drive off of the SATA connector.
    • Warning: Don’t wiggle the SATA connector or the top piece will come off. If it does, reconnect it vertically.
结论
另外一个人完成了本指南。
Shannon
于04/11/13注册
55 声望
创作了6篇指南
团队
Cal Poly, Team 13-66, Johann Spring 2013 Cal Poly, Team 13-66, Johann Spring 2013 的会员
CPSU-JOHANN-S13S13G66
3 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 8
总计 535
