当前版本的文档还未经巡查,您可以查看最新的已查核版本。
这个步骤还没有翻译 帮忙翻译一下
Start with the bottom of the laptop facing up.
Locate the battery compartment at the rear of the device.
There is a slider button located under the left side of the battery compartment. It is indicated by a battery symbol. Move the slider to the left and lift the battery out.
Locate the locking screw which is located in a recessed hole on the underside of the laptop.
Remove the M2.5X3-Lg #1 Phillips screw.
Locate the CD drive tray release hole on the front of the drive.
Straighten a paper clip and push it gently into the CD drive tray release hole.
The drive tray will pop open.
Grasp the side edges of the drive tray.
Gently pull the drive from the laptop.
Locate the mounting bracket which is attached to the back of the drive.
Remove the two M2x3-Lg #0 Phillips screws.
取消:我没有完成这个指南。
另外一个人完成了本指南。
与2其他贡献者
于03/12/14注册
239 声望
创作了2篇指南
徽章: 6
+ 3更多徽章
UMASSD-VIJAYBHASKAR-S14S6G5
3 名成员
创作了3篇指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
过去 24 小时: 2
过去 7 天: 10
过去 30 天: 11
总计 239
