跳转到主内容
HP Pavilion DV2160BR DVD±RW Drive Replacement
你所需要的
  1. HP Pavilion DV2160BR DVD±RW Drive Replacement, Battery: 步骤 1 中的图像 1,1
    • Start with the bottom of the laptop facing up.
  2. HP Pavilion DV2160BR DVD±RW Drive Replacement: 步骤 2 中的图像 1,2 HP Pavilion DV2160BR DVD±RW Drive Replacement: 步骤 2 中的图像 2,2
    • Locate the battery compartment at the rear of the device.
    • There is a slider button located under the left side of the battery compartment. It is indicated by a battery symbol. Move the slider to the left and lift the battery out.
  3. HP Pavilion DV2160BR DVD±RW Drive Replacement, DVD±RW Drive: 步骤 3 中的图像 1,1
    • Locate the locking screw which is located in a recessed hole on the underside of the laptop.
    • Remove the M2.5X3-Lg #1 Phillips screw.
  4. HP Pavilion DV2160BR DVD±RW Drive Replacement: 步骤 4 中的图像 1,2 HP Pavilion DV2160BR DVD±RW Drive Replacement: 步骤 4 中的图像 2,2
    • Locate the CD drive tray release hole on the front of the drive.
    • Straighten a paper clip and push it gently into the CD drive tray release hole.
    • The drive tray will pop open.
  5. HP Pavilion DV2160BR DVD±RW Drive Replacement: 步骤 5 中的图像 1,1
    • Grasp the side edges of the drive tray.
    • Gently pull the drive from the laptop.
  6. HP Pavilion DV2160BR DVD±RW Drive Replacement: 步骤 6 中的图像 1,1
    • Locate the mounting bracket which is attached to the back of the drive.
    • Remove the two M2x3-Lg #0 Phillips screws.
结论
另外一个人完成了本指南。
团队
UMass Dartmouth, Team 6-5, Vijaybhaskar Spring 2014 UMass Dartmouth, Team 6-5, Vijaybhaskar Spring 2014 的会员
UMASSD-VIJAYBHASKAR-S14S6G5
3 名成员
创作了3篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 3
总计 244
