简介
In this guide you will learn how to remove the DVD±RW Drive from an HP Pavilion DV2160BR.
  1. Start with the bottom of the laptop facing up.
    • Start with the bottom of the laptop facing up.
  2. Locate the battery compartment at the rear of the device. There is a slider button located under the left side of the battery compartment. It is indicated by a battery symbol. Move the slider to the left and lift the battery out.
    • Locate the battery compartment at the rear of the device.
    • There is a slider button located under the left side of the battery compartment. It is indicated by a battery symbol. Move the slider to the left and lift the battery out.
  3. 所有超过US$100.00或包含 Pro Tech工具包的订单免费送货!
    浏览我们的商店
  4. Locate the  locking screw which is located in a recessed hole on the underside of the laptop.
    • Locate the locking screw which is located in a recessed hole on the underside of the laptop.
    • Remove the M2.5X3-Lg #1 Phillips screw.
  5. Locate the CD drive tray release hole on the front of the drive. Straighten a paper clip and push it gently into the CD drive tray release hole.
    • Locate the CD drive tray release hole on the front of the drive.
    • Straighten a paper clip and push it gently into the CD drive tray release hole.
    • The drive tray will pop open.
  6. Grasp the side edges of the drive tray.
    • Grasp the side edges of the drive tray.
    • Gently pull the drive from the laptop.
  7. Locate the mounting bracket which is attached to the back of  the drive.
    • Locate the mounting bracket which is attached to the back of the drive.
    • Remove the two M2x3-Lg #0 Phillips screws.
结论
另外一个人完成了本指南。
Brandon MacDonald
于2014年03月12日注册
239 信誉积分
创作了2篇指南
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 0
总计 151
