跳转到主内容
HP Pavilion DM3-3010US Hard Drive Replacement
你所需要的
  1. HP Pavilion DM3-3010US Hard Drive Replacement, Hard Drive: 步骤 1 中的图像 1,1
    • Flip laptop over to back with the battery facing downwards.
    • The battery is the silver cylinder located on the bottom of the laptop.
  2. HP Pavilion DM3-3010US Hard Drive Replacement: 步骤 2 中的图像 1,1
    • Locate switch for battery ejection.
    • Battery ejection switch is located just above the left side of the battery.
  3. HP Pavilion DM3-3010US Hard Drive Replacement: 步骤 3 中的图像 1,1
    • Remove battery by sliding the battery ejection switch to the right and pulling the battery away from the laptop.
  4. HP Pavilion DM3-3010US Hard Drive Replacement: 步骤 4 中的图像 1,2 HP Pavilion DM3-3010US Hard Drive Replacement: 步骤 4 中的图像 2,2
    • Using a plastic opening tool, remove the large square casing located on the bottom right side of the laptop.
    • The hard drive will be visible once the casing has been removed.
  5. HP Pavilion DM3-3010US Hard Drive Replacement: 步骤 5 中的图像 1,2 HP Pavilion DM3-3010US Hard Drive Replacement: 步骤 5 中的图像 2,2
    • Using a Phillips #0 Screwdriver, remove each of the six Phillips #0 screws.
    • Four screws are located on each corner of the hard-drive.
    • Two screws are located on the right side of the battery slot.
  6. HP Pavilion DM3-3010US Hard Drive Replacement: 步骤 6 中的图像 1,1
    • Remove old hard drive from its slot and replace with new hard drive, sticker side facing up.
结论
2等其他人完成本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 8
总计 1,863
