跳转到主内容
HP Pavilion 500-259 Hard Drive Replacement
你所需要的
  1. HP Pavilion 500-259 Hard Drive Replacement, Hard Drive: 步骤 1 中的图像 1,2 HP Pavilion 500-259 Hard Drive Replacement, Hard Drive: 步骤 1 中的图像 2,2
    • Power down and unplug all wires from the computer before proceeding.
    • Use a Phillips #1 screwdriver to remove the single 6 mm screw securing the side panel.
    • These screws can often be removed by hand.
  2. HP Pavilion 500-259 Hard Drive Replacement: 步骤 2 中的图像 1,2 HP Pavilion 500-259 Hard Drive Replacement: 步骤 2 中的图像 2,2
    • Slide the front panel back and off the chassis.
  3. HP Pavilion 500-259 Hard Drive Replacement: 步骤 3 中的图像 1,3 HP Pavilion 500-259 Hard Drive Replacement: 步骤 3 中的图像 2,3 HP Pavilion 500-259 Hard Drive Replacement: 步骤 3 中的图像 3,3
    • The hard drive is found on the left-hand side of the case.
  4. HP Pavilion 500-259 Hard Drive Replacement: 步骤 4 中的图像 1,3 HP Pavilion 500-259 Hard Drive Replacement: 步骤 4 中的图像 2,3 HP Pavilion 500-259 Hard Drive Replacement: 步骤 4 中的图像 3,3
    • Unplug the two cables attached to the back of the hard drive.
  5. HP Pavilion 500-259 Hard Drive Replacement: 步骤 5 中的图像 1,1
    • Place one hand underneath the hard drive to prevent it from falling, then remove the two 2 mm screws attaching the hard drive to the case with a Phillips #2 screwdriver.
  6. HP Pavilion 500-259 Hard Drive Replacement: 步骤 6 中的图像 1,3 HP Pavilion 500-259 Hard Drive Replacement: 步骤 6 中的图像 2,3 HP Pavilion 500-259 Hard Drive Replacement: 步骤 6 中的图像 3,3
    • Slide the hard drive out of the case.
结论
6等其他人完成本指南。
Farhan Khan
于01/15/22注册
283 声望
撰写一个指南
团队
2条评论
Why does it look like that drive is mounted sideways with just two screws? The original 3.5" hard drive is mounted flat to the lower 3.5 in mounting Bay. I was looking for advice on how to mount the SSD to the upper 2.5 in mounting Bay. I have serious doubts about the instructions you've posted.
Dave Hill - 回复
Hello Dave, this particular HP Pavilion desktop had the hard-drive mounted sideways with two screws, the 2.5" hard-drive being as lightweight as it was able to be supported by just the two screws. I made this guide about a year ago and cannot remember if the hard-drive was able to be mounted flat with the given hole placements. However, I have linked a Youtube video down below that might provide some assistance when trying to mount your 2.5" hard drive despite the video showing a 3.5" drive.
HP Hard drive replacement video: https://www.youtube.com/watch?v=PxT_qPzl...
Thank you for taking the time to look at my guide and I hope this response provides at least a little assistance.
Farhan Khan -
添加评论
浏览统计数据:
过去 24 小时: 13
过去 7 天: 27
过去 30 天: 131
总计 2,625
