简介
Do you have an old laptop that has slowed down? Tired of performance issues ruining your gaming experience? Random Access Memory (RAM), often referred to simply as "memory," helps store data that must be readily available to run various programs. If you play demanding games on an older laptop or use programs that take up a lot of memory, your laptop probably won't perform at its best. While most of the processing power is handled by the laptop's graphics card, the amount of available RAM also helps improve your overall performance.
If your laptop struggles to load programs and becomes unresponsive during heavy gaming sessions, it's probably time for an upgrade. Computer RAM lets you run data-intensive applications with ease and increases the multitasking capabilities of the laptop. Running multiple programs at the same time often causes performance issues because each application in use requires a different amount of memory. If you like to play games, surf the web, stream and chat online at the same time, you need to make sure you have enough RAM to handle all these tasks.
你所需要的
The netbook needs to be top-side down with the lid closed.
Slide the plastic battery release latches towards the lock symbols.
Using a Phillips #0 screwdriver, remove thirteen 7.0 mm screws from the back case.
Using a Phillips #0 screwdriver, remove the CD/DVD drive screw.
Use an ejection pin to eject and remove the CD/DVD drive.
