跳转到主内容
HP Pavilion 17-x047na Hard Drive Replacement
你所需要的
  1. HP Pavilion 17-x047na Hard Drive Replacement, Battery: 步骤 1 中的图像 1,2 HP Pavilion 17-x047na Hard Drive Replacement, Battery: 步骤 1 中的图像 2,2
    • Turn off and unplug the laptop before replacing the battery.
    • The netbook needs to be top-side down with the lid closed.
    • Slide the plastic battery release latches towards the lock symbols.
  2. HP Pavilion 17-x047na Hard Drive Replacement: 步骤 2 中的图像 1,1
    • Slide the battery out from the laptop.
  3. HP Pavilion 17-x047na Hard Drive Replacement, Back Panel: 步骤 3 中的图像 1,2 HP Pavilion 17-x047na Hard Drive Replacement, Back Panel: 步骤 3 中的图像 2,2
    • Using a Phillips #0 screwdriver, remove thirteen 7.0 mm screws from the back case.
    • Using a Phillips #0 screwdriver, remove the CD/DVD drive screw.
    • Use an ejection pin to eject and remove the CD/DVD drive.
  4. HP Pavilion 17-x047na Hard Drive Replacement: 步骤 4 中的图像 1,2 HP Pavilion 17-x047na Hard Drive Replacement: 步骤 4 中的图像 2,2
    • Use an iFixit opening tool to separate the back cover from the laptop.
    • Gently pry open the cover, trying not to break the plastic.
  5. HP Pavilion 17-x047na Hard Drive Replacement, Hard Drive: 步骤 5 中的图像 1,1
    • Locate the hard drive.
  6. HP Pavilion 17-x047na Hard Drive Replacement: 步骤 6 中的图像 1,3 HP Pavilion 17-x047na Hard Drive Replacement: 步骤 6 中的图像 2,3 HP Pavilion 17-x047na Hard Drive Replacement: 步骤 6 中的图像 3,3
    • To remove the hard drive, lift both latches to remove the ribbon cable.
    • Once ribbon cable is removed, use the rubber case surrounding the hard drive to lift upwards and pull the hard drive out.
结论
另外一个人完成了本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 4
总计 404
