简介
RAM is one of the main parts of a computer. RAM stores temporary data in order for your processor to be able to find data quickly instead of going through long-term storage devices to pull data. If your HP Pavilion 17-g192dx is consistently slow and has unresponsive programs, this guide will successfully walk you through step by step on how to replace your RAM in your device. Before you begin, be sure you have the proper tools, located on the right side of this webpage, as well as a new RAM stick that will be replacing the old one.
你所需要的
Use your fingers to pry the two black tabs on either side of the RAM stick outwards until the RAM swings upwards to rest at an angle.
Gently slide the RAM out from the port maintaining the angle at which it rests.
另外一个人完成了本指南。
