跳转到主内容
HP Pavilion 17-g119dx Hard Drive Replacement
你所需要的
  1. HP Pavilion 17-g119dx Hard Drive Replacement, Battery: 步骤 1 中的图像 1,1
    • Close your laptop and turn it over so that the bottom is facing up.
  2. HP Pavilion 17-g119dx Hard Drive Replacement: 步骤 2 中的图像 1,2 HP Pavilion 17-g119dx Hard Drive Replacement: 步骤 2 中的图像 2,2
    • In the upper left hand corner, slide the bar with the lock icon to the right. This will unlock the battery.
  3. HP Pavilion 17-g119dx Hard Drive Replacement: 步骤 3 中的图像 1,2 HP Pavilion 17-g119dx Hard Drive Replacement: 步骤 3 中的图像 2,2
    • Slide the bar with the battery icon, on the right of your laptop, to the left to release the battery.
  4. HP Pavilion 17-g119dx Hard Drive Replacement: 步骤 4 中的图像 1,2 HP Pavilion 17-g119dx Hard Drive Replacement: 步骤 4 中的图像 2,2
    • Grab the battery and remove it from the laptop.
  5. HP Pavilion 17-g119dx Hard Drive Replacement, Hard Drive: 步骤 5 中的图像 1,3 HP Pavilion 17-g119dx Hard Drive Replacement, Hard Drive: 步骤 5 中的图像 2,3 HP Pavilion 17-g119dx Hard Drive Replacement, Hard Drive: 步骤 5 中的图像 3,3
    • Remove the twenty 6.5mm screws using the Phillips #00 screwdriver.
    • Two of these 6.5mm screws are covered by a silver sticker. Remove the sticker by gently scraping your finger nail under the sticker and then remove the screws.
  6. HP Pavilion 17-g119dx Hard Drive Replacement: 步骤 6 中的图像 1,3 HP Pavilion 17-g119dx Hard Drive Replacement: 步骤 6 中的图像 2,3 HP Pavilion 17-g119dx Hard Drive Replacement: 步骤 6 中的图像 3,3
    • Remove the black corner covers on either side of the battery to reveal four additional 6.5mm Phillips #00 screws.
  7. HP Pavilion 17-g119dx Hard Drive Replacement: 步骤 7 中的图像 1,3 HP Pavilion 17-g119dx Hard Drive Replacement: 步骤 7 中的图像 2,3 HP Pavilion 17-g119dx Hard Drive Replacement: 步骤 7 中的图像 3,3
    • Remove the four 6.5mm Phillips #00 screws that were underneath the black corner covers.
  8. HP Pavilion 17-g119dx Hard Drive Replacement: 步骤 8 中的图像 1,3 HP Pavilion 17-g119dx Hard Drive Replacement: 步骤 8 中的图像 2,3 HP Pavilion 17-g119dx Hard Drive Replacement: 步骤 8 中的图像 3,3
    • On the right-hand corner of the laptop, remove the CD-ROM by pressing the small button on the side. Pull it out of the laptop, and set it to the side.
  9. HP Pavilion 17-g119dx Hard Drive Replacement: 步骤 9 中的图像 1,3 HP Pavilion 17-g119dx Hard Drive Replacement: 步骤 9 中的图像 2,3 HP Pavilion 17-g119dx Hard Drive Replacement: 步骤 9 中的图像 3,3
    在这个步骤中使用的工具:
    iFixit Opening Tool
    $1.99
    购买
    • Make sure that all screws and the CD-ROM Drive are removed before trying to complete this step to prevent damaging your laptop. During this step, you will likely hear loud crackling noises. This is normal.
    • Flip the computer back over with the screen facing up and open the laptop.
    • Use the Plastic Opening Tool to separate the face plate from the backing.
  10. HP Pavilion 17-g119dx Hard Drive Replacement: 步骤 10 中的图像 1,2 HP Pavilion 17-g119dx Hard Drive Replacement: 步骤 10 中的图像 2,2
    • After running the opening tool along the sides, you can gently pop the keyboard open to access the Hard Drive.
    • The Hard Drive is located to the right of the RAM and above the Motherboard.
  11. HP Pavilion 17-g119dx Hard Drive Replacement: 步骤 11 中的图像 1,3 HP Pavilion 17-g119dx Hard Drive Replacement: 步骤 11 中的图像 2,3 HP Pavilion 17-g119dx Hard Drive Replacement: 步骤 11 中的图像 3,3
    • To remove the Hard Drive, disconnect it from the cable by pulling out the base. Do not pull on the ribbon.
结论
18等其他人完成本指南。
2条评论
Very helpful, thank you!
TCATDI - 回复
Thnx indeed very helpful.
Willem Zweedyk - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 5
过去 30 天: 28
总计 11,306
