简介
A broken fan can cause the device to overheat and run slow. In this guide, you will learn how to replace your HP Pavilion 17-g119dx laptop's fan. To perform the replacement, you will need a Phillips head screwdriver and a plastic opening tool to pop open the keyboard.
你所需要的
Flip the computer back over with the screen facing up and open the laptop.
Use the Plastic Opening Tool to separate the face plate from the backing.
Unscrew the two 0.5 mm screws using a Phillips #00 screwdriver.
即将完成!
结论
