简介
A broken fan can cause the device to overheat and run slow. In this guide, you will learn how to replace your HP Pavilion 17-g119dx laptop's fan. To perform the replacement, you will need a Phillips head screwdriver and a plastic opening tool to pop open the keyboard.
你所需要的
在这个步骤中使用的工具:iFixit Opening Tool$1.99
Flip the computer back over with the screen facing up and open the laptop.
Use the Plastic Opening Tool to separate the face plate from the backing.
在这个步骤中使用的工具:Phillips #00 Screwdriver$5.49
Unscrew the two 0.5 mm screws using a Phillips #00 screwdriver.
即将完成!
结论
