跳转到主内容
HP Pavilion 17-f127ds Speakers Replacement
你所需要的
  1. HP Pavilion 17-f127ds Speakers Replacement, Battery: 步骤 1 中的图像 1,3 HP Pavilion 17-f127ds Speakers Replacement, Battery: 步骤 1 中的图像 2,3 HP Pavilion 17-f127ds Speakers Replacement, Battery: 步骤 1 中的图像 3,3
    • Before starting, please turn off your laptop.
    • Slide the battery lock latch, the latch on the left, inwards.
    • Slide the battery release latch on the right inwards to release the battery.
    • The latch may require significant force to slide.
    • Lift the battery up and remove it from computer.
  2. HP Pavilion 17-f127ds Speakers Replacement, Keyboard: 步骤 2 中的图像 1,2 HP Pavilion 17-f127ds Speakers Replacement, Keyboard: 步骤 2 中的图像 2,2
    • Flip your laptop over on a firm surface.
    • Using a Phillips #1 screwdriver, remove the thirteen screws on the back of your laptop.
    • Flip your laptop back over.
  3. HP Pavilion 17-f127ds Speakers Replacement: 步骤 3 中的图像 1,3 HP Pavilion 17-f127ds Speakers Replacement: 步骤 3 中的图像 2,3 HP Pavilion 17-f127ds Speakers Replacement: 步骤 3 中的图像 3,3
    • Using the opening tools, separate the keyboard from the laptop by prying it from the base along the sides of the laptop.
    • With your fingers, disconnect the keyboard connector and the connector cable from the motherboard.
    • Be careful not to lift the keyboard too high because it might rip off the connectors.
    • Carefully remove the keyboard.
  4. HP Pavilion 17-f127ds Speakers Replacement, Speakers: 步骤 4 中的图像 1,2 HP Pavilion 17-f127ds Speakers Replacement, Speakers: 步骤 4 中的图像 2,2
    • Disconnect the tape connecting the WLAN module to the main board.
    • With a Phillips #0 screwdriver remove the remaining screw holding the speaker in place.
  5. HP Pavilion 17-f127ds Speakers Replacement: 步骤 5 中的图像 1,2 HP Pavilion 17-f127ds Speakers Replacement: 步骤 5 中的图像 2,2
    • Disconnect the speakers from the main board.
    • Lift away the speakers, they are connected with a wire.
结论
Stephen Brown
于10/18/17注册
201 声望
创作了2篇指南
团队
UW Tacoma, Team S3-G1, Liner Fall 2017 UW Tacoma, Team S3-G1, Liner Fall 2017 的会员
UWT-LINER-F17S3G1
5 名成员
创作了4篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 15
总计 412
