跳转到主内容
HP Pavilion 17-f127ds Optical Drive Replacement
你所需要的
  1. HP Pavilion 17-f127ds Optical Drive Replacement, Battery: 步骤 1 中的图像 1,3 HP Pavilion 17-f127ds Optical Drive Replacement, Battery: 步骤 1 中的图像 2,3 HP Pavilion 17-f127ds Optical Drive Replacement, Battery: 步骤 1 中的图像 3,3
    • Before starting, please turn off your laptop.
    • Slide the battery lock latch, the latch on the left, inwards.
    • Slide the battery release latch on the right inwards to release the battery.
    • The latch may require significant force to slide.
    • Lift the battery up and remove it from computer.
  2. HP Pavilion 17-f127ds Optical Drive Replacement, Optical Drive: 步骤 2 中的图像 1,2 HP Pavilion 17-f127ds Optical Drive Replacement, Optical Drive: 步骤 2 中的图像 2,2
    • Use a Phillips #1 screwdriver to remove the screw holding the Optical Drive in place. It is located near the center and vents of the laptop.
    • Use a spudger to help unseat the drive. Pull the drive out from the laptop.
  3. HP Pavilion 17-f127ds Optical Drive Replacement: 步骤 3 中的图像 1,1
    • If you need to replace the bracket on the Optical drive, remove the two Phillips #0 screws holding the bracket in place. The bracket can be placed on the new drive.
结论
Stephen Brown
于10/18/17注册
201 声望
创作了2篇指南
团队
UW Tacoma, Team S3-G1, Liner Fall 2017 UW Tacoma, Team S3-G1, Liner Fall 2017 的会员
UWT-LINER-F17S3G1
5 名成员
创作了4篇指南
一条评论
I can’t remove the HP Pavilion 17-x016ds Optical Drive. NEED HELP. Is it necessary to remove it in order to remove bottom panel to replace HDD with SSD? Also can’t remove bottom panel.
Nick Koriakin - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 16
总计 965
