跳转到主内容
HP Pavilion 17-f004dx Front Panel Replacement
你所需要的
  1. HP Pavilion 17-f004dx Front Panel Replacement, Battery: 步骤 1 中的图像 1,1
    • Before you remove the battery, make sure the laptop is powered off.
    • Slide the black battery latches inward to remove the battery.
  2. HP Pavilion 17-f004dx Front Panel Replacement: 步骤 2 中的图像 1,1
    • Pull the battery out towards you while your fingers are still holding the latches in place.
  3. HP Pavilion 17-f004dx Front Panel Replacement, CD Drive: 步骤 3 中的图像 1,1
    • Remove one 7 mm screw with a Phillips #1 screwdriver.
  4. HP Pavilion 17-f004dx Front Panel Replacement: 步骤 4 中的图像 1,3 HP Pavilion 17-f004dx Front Panel Replacement: 步骤 4 中的图像 2,3 HP Pavilion 17-f004dx Front Panel Replacement: 步骤 4 中的图像 3,3
    • Use a metal spudger to push the CD drive out of its slot for removal.
  5. HP Pavilion 17-f004dx Front Panel Replacement, Front Panel: 步骤 5 中的图像 1,1
    • Remove fifteen 7 mm screws with a Phillips #1 screwdriver.
  6. HP Pavilion 17-f004dx Front Panel Replacement: 步骤 6 中的图像 1,2 HP Pavilion 17-f004dx Front Panel Replacement: 步骤 6 中的图像 2,2
    • Remove the thin plastic cover using the flat metal spudger to expose another screw.
    • Remove one 7 mm screw with a Phillips #0 screwdriver.
  7. HP Pavilion 17-f004dx Front Panel Replacement: 步骤 7 中的图像 1,2 HP Pavilion 17-f004dx Front Panel Replacement: 步骤 7 中的图像 2,2
    • Use a metal spudger to remove the rubber "feet" to expose two screws.
  8. HP Pavilion 17-f004dx Front Panel Replacement: 步骤 8 中的图像 1,1
    • Underneath each rubber foot, there is a screw.
    • Use the Phillips #1 screwdriver to remove a 4.8 mm screw on each side.
  9. HP Pavilion 17-f004dx Front Panel Replacement: 步骤 9 中的图像 1,1
    • Remove the two black end caps to expose more screws.
    • The end caps will require some force to remove.
  10. HP Pavilion 17-f004dx Front Panel Replacement: 步骤 10 中的图像 1,1
    • Remove the following six screws with a Phillips #1 screwdriver:
    • Two 7 mm screws.
    • Two 7 mm screws.
    • Two 4.8 mm screws.
  11. HP Pavilion 17-f004dx Front Panel Replacement: 步骤 11 中的图像 1,1
    • Remove two 2.4 mm broadhead screws from the CD Drive bay with a Phillips #0 screwdriver.
  12. HP Pavilion 17-f004dx Front Panel Replacement: 步骤 12 中的图像 1,2 HP Pavilion 17-f004dx Front Panel Replacement: 步骤 12 中的图像 2,2
    • Flip the laptop back over. Then, with the laptop open, move the plastic prying tool around the top cover to pry it from the enclosure.
  13. HP Pavilion 17-f004dx Front Panel Replacement: 步骤 13 中的图像 1,1
    • Partially lift the top cover from the enclosure.
  14. HP Pavilion 17-f004dx Front Panel Replacement: 步骤 14 中的图像 1,2 HP Pavilion 17-f004dx Front Panel Replacement: 步骤 14 中的图像 2,2
    • Remove the ribbon connecting the power button to the motherboard.
  15. HP Pavilion 17-f004dx Front Panel Replacement: 步骤 15 中的图像 1,2 HP Pavilion 17-f004dx Front Panel Replacement: 步骤 15 中的图像 2,2
    • Remove the ribbon connecting the mousepad to the motherboard.
  16. HP Pavilion 17-f004dx Front Panel Replacement: 步骤 16 中的图像 1,2 HP Pavilion 17-f004dx Front Panel Replacement: 步骤 16 中的图像 2,2
    • Remove the ribbon connecting the keyboard to the motherboard.
    • You may now fully lift the front panel from the rest of the laptop.
结论
另外一个人完成了本指南。
Allan Soria
于09/21/16注册
638 声望
创作了4篇指南
团队
UC Davis, Team 1-4, Oliver Fall 2016 UC Davis, Team 1-4, Oliver Fall 2016 的会员
UCD-OLIVER-F16S1G4
4 名成员
创作了8篇指南
1指南评论
I need the fan , how much?
محمد السيد - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 8
总计 1,337
