跳转到主内容
HP Pavilion 17-e146us Keyboard Replacement
你所需要的
  1. HP Pavilion 17-e146us Keyboard Replacement, Battery: 步骤 1 中的图像 1,1
    • Turn the device over.
  2. HP Pavilion 17-e146us Keyboard Replacement: 步骤 2 中的图像 1,2 HP Pavilion 17-e146us Keyboard Replacement: 步骤 2 中的图像 2,2
    • Move the battery lock switch to the right to unlock. The battery release button will unlock the battery from the computer.
    • The battery release button is located above the the battery.
  3. HP Pavilion 17-e146us Keyboard Replacement: 步骤 3 中的图像 1,1
    • The battery will unlock from the computer.
    • Remove the unlocked battery from the computer.
  4. HP Pavilion 17-e146us Keyboard Replacement, Keyboard: 步骤 4 中的图像 1,3 HP Pavilion 17-e146us Keyboard Replacement, Keyboard: 步骤 4 中的图像 2,3 HP Pavilion 17-e146us Keyboard Replacement, Keyboard: 步骤 4 中的图像 3,3
    • Remove the 6.25 mm screw in the left-lower hand corner of the battery port using a Phillips head screw driver.
  5. HP Pavilion 17-e146us Keyboard Replacement: 步骤 5 中的图像 1,1
    • Remove the HP protect smart ventilation case.
    • The smart ventilation is a part of the back cover of the device
  6. HP Pavilion 17-e146us Keyboard Replacement: 步骤 6 中的图像 1,1
    • Remove seven 6.5 mm screws using a Phillips #0 screwdriver.
    • Remove four 3.0 mm screws located in the charger port using a Phillips #0 screwdriver.
  7. HP Pavilion 17-e146us Keyboard Replacement: 步骤 7 中的图像 1,2 HP Pavilion 17-e146us Keyboard Replacement: 步骤 7 中的图像 2,2
    • Pull and remove the disk drive.
    • The disk drive is located on the left side of the device when it is turned over.
    • Remove two 3.00 mm screws on the inside of the disk drive using a Phillips screwdriver.
  8. HP Pavilion 17-e146us Keyboard Replacement: 步骤 8 中的图像 1,1
    在这个步骤中使用的工具:
    购买
    • Apply firm pressure inside the release port using a narrow tool such as a screw driver or tweezers.
    • The release port releases the keyboard.
  9. HP Pavilion 17-e146us Keyboard Replacement: 步骤 9 中的图像 1,1
    • Flip device over so that the cover is facing towards you
  10. HP Pavilion 17-e146us Keyboard Replacement: 步骤 10 中的图像 1,3 HP Pavilion 17-e146us Keyboard Replacement: 步骤 10 中的图像 2,3 HP Pavilion 17-e146us Keyboard Replacement: 步骤 10 中的图像 3,3
    • Open device. The keyboard should be separate from the inside panel.
    • If the keyboard does not automatically pop out, use a spudger or opening tool along the edge of the front panel and the keyboard to pop the keyboard out.
    • Detach the keyboard's cable connector from the motherboard.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 13
总计 756
