跳转到主内容
HP Pavilion 17-e020dx RAM Replacement
你所需要的
  1. HP Pavilion 17-e020dx RAM Replacement, RAM: 步骤 1 中的图像 1,3 HP Pavilion 17-e020dx RAM Replacement, RAM: 步骤 1 中的图像 2,3 HP Pavilion 17-e020dx RAM Replacement, RAM: 步骤 1 中的图像 3,3
    • Locate the battery release switch on the bottom of the device.
    • Push the switch to the left to release the battery.
    • Remove the battery by lifting upwards from the raised edge of the battery.
  2. HP Pavilion 17-e020dx RAM Replacement: 步骤 2 中的图像 1,3 HP Pavilion 17-e020dx RAM Replacement: 步骤 2 中的图像 2,3 HP Pavilion 17-e020dx RAM Replacement: 步骤 2 中的图像 3,3
    • Loosen the screw under the battery with a Phillips #00 screwdriver.
    • The screw will not come out completely. Loosen the screw until it moves freely in its place.
    • Slide the access tray back until it pops out of its slots.
    • Lift upwards to remove the access tray.
  3. HP Pavilion 17-e020dx RAM Replacement: 步骤 3 中的图像 1,3 HP Pavilion 17-e020dx RAM Replacement: 步骤 3 中的图像 2,3 HP Pavilion 17-e020dx RAM Replacement: 步骤 3 中的图像 3,3
    • Using a nylon spudger, push the two clips on the top stick of RAM to the side.
    • The top stick of RAM will pop up when both clips are pushed away.
    • Remove the top stick of RAM by grabbing it on both ends of the stick.
  4. HP Pavilion 17-e020dx RAM Replacement: 步骤 4 中的图像 1,2 HP Pavilion 17-e020dx RAM Replacement: 步骤 4 中的图像 2,2
    • Repeat step 3 on the bottom stick of RAM.
  5. HP Pavilion 17-e020dx RAM Replacement: 步骤 5 中的图像 1,3 HP Pavilion 17-e020dx RAM Replacement: 步骤 5 中的图像 2,3 HP Pavilion 17-e020dx RAM Replacement: 步骤 5 中的图像 3,3
    • To install the new RAM, grab the RAM by both end.
    • Align the slot of the bottom stick of RAM with the pin in the bottom connector, and push the RAM into the connector until the gold pins are no longer showing.
    • Gently push down on the top of the RAM until the clips click into place.
  6. HP Pavilion 17-e020dx RAM Replacement: 步骤 6 中的图像 1,2 HP Pavilion 17-e020dx RAM Replacement: 步骤 6 中的图像 2,2
    • Repeat step 5 with the top stick of RAM.
  7. HP Pavilion 17-e020dx RAM Replacement: 步骤 7 中的图像 1,3 HP Pavilion 17-e020dx RAM Replacement: 步骤 7 中的图像 2,3 HP Pavilion 17-e020dx RAM Replacement: 步骤 7 中的图像 3,3
    • Align the access tray onto the bottom of the device and firmly push forward until it pops into place.
    • Tighten the screw in the battery tray until just snug. Do not over tighten this screw.
    • Reinstall the battery by placing the top in first and pressing down until you hear a click.
结论
You have successfully replaced the RAM in your device, and your HP Pavillion 17-e020dx should now operate at normal speeds again.
Dylan Hayes
于03/23/20注册
145 声望
撰写一个指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 10
过去 30 天: 17
总计 847
