跳转到主内容
HP Pavilion 17 TS Wireless Card Replacement
你所需要的
  1. HP Pavilion 17 TS Wireless Card Replacement, Battery: 步骤 1 中的图像 1,3 HP Pavilion 17 TS Wireless Card Replacement, Battery: 步骤 1 中的图像 2,3 HP Pavilion 17 TS Wireless Card Replacement, Battery: 步骤 1 中的图像 3,3
    • Press and hold the release switch, and then slide the battery out. Insert the new battery into the slot and you're done!
  2. HP Pavilion 17 TS Wireless Card Replacement, Rear Cover: 步骤 2 中的图像 1,3 HP Pavilion 17 TS Wireless Card Replacement, Rear Cover: 步骤 2 中的图像 2,3 HP Pavilion 17 TS Wireless Card Replacement, Rear Cover: 步骤 2 中的图像 3,3
    • In the battery compartment, find the phillips screw that is holding the rear panel onto the computer. Unscrew it.
    • With the battery compartment closest to you, push the panel away from you. Once it slides back until it stops, gently lift it and put it to the side.
    • Please note that this particular screw does not completely come out, it stays with the rear panel and that is ok.
  3. HP Pavilion 17 TS Wireless Card Replacement, Wireless Card: 步骤 3 中的图像 1,3 HP Pavilion 17 TS Wireless Card Replacement, Wireless Card: 步骤 3 中的图像 2,3 HP Pavilion 17 TS Wireless Card Replacement, Wireless Card: 步骤 3 中的图像 3,3
    在这个步骤中使用的工具:
    购买
    • Undo the two clips attached to the wifi chip by pulling up gently with a pair of tweezers.
    • Unscrew the 9mm phillips screw holding the wifi chip in place.
    • Gently remove the wifi chip from its socket and place it to the side.
结论
另外一个人完成了本指南。
Sean Croft
于03/25/16注册
739 声望
创作了5篇指南
团队
UMass Dartmouth, Team 1-6, Miles Spring 2016 UMass Dartmouth, Team 1-6, Miles Spring 2016 的会员
UMASSD-MILES-S16S1G6
3 名成员
创作了9篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 4
总计 294
