跳转到主内容
HP Pavilion 17 TS Disk Drive Replacement
你所需要的
  1. HP Pavilion 17 TS Disk Drive Replacement, Battery: 步骤 1 中的图像 1,3 HP Pavilion 17 TS Disk Drive Replacement, Battery: 步骤 1 中的图像 2,3 HP Pavilion 17 TS Disk Drive Replacement, Battery: 步骤 1 中的图像 3,3
    • Press and hold the release switch, and then slide the battery out. Insert the new battery into the slot and you're done!
  2. HP Pavilion 17 TS Disk Drive Replacement, Rear Cover: 步骤 2 中的图像 1,3 HP Pavilion 17 TS Disk Drive Replacement, Rear Cover: 步骤 2 中的图像 2,3 HP Pavilion 17 TS Disk Drive Replacement, Rear Cover: 步骤 2 中的图像 3,3
    • In the battery compartment, find the phillips screw that is holding the rear panel onto the computer. Unscrew it.
    • With the battery compartment closest to you, push the panel away from you. Once it slides back until it stops, gently lift it and put it to the side.
    • Please note that this particular screw does not completely come out, it stays with the rear panel and that is ok.
  3. HP Pavilion 17 TS Disk Drive Replacement, Disk Drive: 步骤 3 中的图像 1,3 HP Pavilion 17 TS Disk Drive Replacement, Disk Drive: 步骤 3 中的图像 2,3 HP Pavilion 17 TS Disk Drive Replacement, Disk Drive: 步骤 3 中的图像 3,3
    • With the battery compartment closest to you, there will be a 9mm screw next in the center-right of the back plate, labeled with a keyboard symbol and a disk symbol. Remove this phillips screw.
    • In the opening next to the screw, gently push out against the disk drive, and remove it from the disk drive compartment.
结论
Eric Sowersby
于03/25/16注册
413 声望
创作了4篇指南
团队
UMass Dartmouth, Team 1-6, Miles Spring 2016 UMass Dartmouth, Team 1-6, Miles Spring 2016 的会员
UMASSD-MILES-S16S1G6
3 名成员
创作了9篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 6
总计 540
