跳转到主内容
HP Pavilion 15-p214dx Disk Drive Replacement
你所需要的
  1. HP Pavilion 15-p214dx Disk Drive Replacement, Disk Drive: 步骤 1 中的图像 1,3 HP Pavilion 15-p214dx Disk Drive Replacement, Disk Drive: 步骤 1 中的图像 2,3 HP Pavilion 15-p214dx Disk Drive Replacement, Disk Drive: 步骤 1 中的图像 3,3
    • Place your laptop on a flat surface with the bottom facing upwards. The HP logo should be facing downwards.
    • Locate the disk drive screw. It is a 7mm screw that can be found to the upper left on label on the bottom of the computer and is marked with a disk drive symbol.
    • Remove this screw using a Philips #0 screwdriver.
  2. HP Pavilion 15-p214dx Disk Drive Replacement: 步骤 2 中的图像 1,2 HP Pavilion 15-p214dx Disk Drive Replacement: 步骤 2 中的图像 2,2
    • Place your thumbnail between the disk drive exterior and your laptop's bottom cover.
    • If your nail is not long enough to do this, you can use a prying tool instead.
    • Pull outwards to slide the disk drive out of its slot.
    • Due to how the disk drive's slot is constructed, the drive must be properly aligned to fit back in. It may take a couple attempts to properly align it.
结论
Patrick Seaver
于03/25/19注册
1,001 声望
创作了8篇指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 9
总计 275
