简介
This guide will show you how to remove your HP Pavilion 15-p214dx’s battery if you need to remove or replace it. The only tools you need to complete this guide are your hands, so completing this task is fairly easy and straightforward.
你所需要的
Slide the battery lock (the switch at the upper left corner of the laptop's underside) to the right until it clicks into place.
即将完成!
To reassemble your device, follow these instructions in reverse order. Opening the battery release latch is not required to plug the battery back in.
结论
