跳转到主内容
HP Pavilion 15-p046nr Battery Replacement
  1. HP Pavilion 15-p046nr Battery Replacement, Battery: 步骤 1 中的图像 1,3 HP Pavilion 15-p046nr Battery Replacement, Battery: 步骤 1 中的图像 2,3 HP Pavilion 15-p046nr Battery Replacement, Battery: 步骤 1 中的图像 3,3
    • Flip the laptop over so the bottom is facing up.
    • Place your finger on the top left-hand slide button with the lock symbol.
    • Moving the slide does require some force.
    • Slide the button to the right so that an unlocked symbol is visible.
  2. HP Pavilion 15-p046nr Battery Replacement: 步骤 2 中的图像 1,3 HP Pavilion 15-p046nr Battery Replacement: 步骤 2 中的图像 2,3 HP Pavilion 15-p046nr Battery Replacement: 步骤 2 中的图像 3,3
    • Place your finger or thumb on the top right-hand slide with the battery symbol visible.
    • Slide the button to the left.
    • Moving the slide will require some force.
    • Lift the battery off the computer with your thumb.
    • You will not need to slide the right button with the battery to reinstall the battery.
结论
另外一个人完成了本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 4
总计 415
