跳转到主内容
HP Pavilion 15-p043cl Repair I/O Replacement
你所需要的
  1. HP Pavilion 15-p043cl Repair I/O Replacement, I/O: 步骤 1 中的图像 1,2 HP Pavilion 15-p043cl Repair I/O Replacement, I/O: 步骤 1 中的图像 2,2
    • Flip the laptop over, showing the backplate face up
  2. HP Pavilion 15-p043cl Repair I/O Replacement: 步骤 2 中的图像 1,3 HP Pavilion 15-p043cl Repair I/O Replacement: 步骤 2 中的图像 2,3 HP Pavilion 15-p043cl Repair I/O Replacement: 步骤 2 中的图像 3,3
    • Use your #1 Phillips-head screwdriver to remove all the 8 mm screws
    • Make sure to put the screws in a magnetic holder or another safe place
  3. HP Pavilion 15-p043cl Repair I/O Replacement: 步骤 3 中的图像 1,3 HP Pavilion 15-p043cl Repair I/O Replacement: 步骤 3 中的图像 2,3 HP Pavilion 15-p043cl Repair I/O Replacement: 步骤 3 中的图像 3,3
    • After removing all the 8 mm screws, start to pry open the optical drive using your finders or a wedge.
  4. HP Pavilion 15-p043cl Repair I/O Replacement: 步骤 4 中的图像 1,2 HP Pavilion 15-p043cl Repair I/O Replacement: 步骤 4 中的图像 2,2
    • Pull out the battery by positioning the switch with the lock symbol on unlock and pushing the switch with the battery towards the center of the laptop.
  5. HP Pavilion 15-p043cl Repair I/O Replacement: 步骤 5 中的图像 1,3 HP Pavilion 15-p043cl Repair I/O Replacement: 步骤 5 中的图像 2,3 HP Pavilion 15-p043cl Repair I/O Replacement: 步骤 5 中的图像 3,3
    • Use an opening pick or wedge to start to pry open the laptop keyboard cover.
    • Follow along the perimeter and separate the cover from the laptop.
  6. HP Pavilion 15-p043cl Repair I/O Replacement: 步骤 6 中的图像 1,3 HP Pavilion 15-p043cl Repair I/O Replacement: 步骤 6 中的图像 2,3 HP Pavilion 15-p043cl Repair I/O Replacement: 步骤 6 中的图像 3,3
    • Carefully remove the keyboard assembly.
    • Make sure to unplug the 3 ribbon cables connecting the keyboard, mousepad and power button to the motherboard
  7. HP Pavilion 15-p043cl Repair I/O Replacement: 步骤 7 中的图像 1,2 HP Pavilion 15-p043cl Repair I/O Replacement: 步骤 7 中的图像 2,2
    • Locate the I/O ports, and remove the bottom most ribbon cable.
  8. HP Pavilion 15-p043cl Repair I/O Replacement: 步骤 8 中的图像 1,3 HP Pavilion 15-p043cl Repair I/O Replacement: 步骤 8 中的图像 2,3 HP Pavilion 15-p043cl Repair I/O Replacement: 步骤 8 中的图像 3,3
    • Locate and remove the screw holding the I/O board in.
    • Once the screw has been removed lift the I/O board straight up and out of the case.
结论
另外一个人完成了本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 7
总计 108
