跳转到主内容
简介
If you have a problem with the keyboard or trackpad and need to replace it, clean the dust in the system fan or gain component access this guide will show you how to remove the palmrest.
Guide notes
  • While the keyboard cable is very long, the trackpad cable is substantially shorter. Use caution when disconnecting the trackpad connector.
  • In order to disassemble this system, it needs to be disassembled top to bottom. Make sure the keyboard, trackpad and power button are disconnected before removing the palmrest.
  • This is a difficult repair. It is a good idea to have a way to sort your screws as there will be two screws to remove the palmrest. This laptop uses multiple screw lengths.
配件
  1. Shut the laptop down until it is hibernated or shut off. Do  not remove power until both lights turn off. Shut the laptop down until it is hibernated or shut off. Do  not remove power until both lights turn off. Shut the laptop down until it is hibernated or shut off. Do  not remove power until both lights turn off.
    • Shut the laptop down until it is hibernated or shut off. Do not remove power until both lights turn off.
  2. Once the computer is off, remove the battery. Switch the locking tab to the unlocked position. Once the computer is off, remove the battery. Switch the locking tab to the unlocked position. Once the computer is off, remove the battery. Switch the locking tab to the unlocked position.
    • Once the computer is off, remove the battery. Switch the locking tab to the unlocked position.
  3. Remove the battery. Pull the battery forward and remove it from the laptop. Remove the battery. Pull the battery forward and remove it from the laptop.
    • Remove the battery. Pull the battery forward and remove it from the laptop.
  4. Remove the screw that holds the optical drive in. To do this, use a Phillips #0 screwdriver. Slide the optical drive out once the screw is removed. Remove the screw that holds the optical drive in. To do this, use a Phillips #0 screwdriver. Slide the optical drive out once the screw is removed. Remove the screw that holds the optical drive in. To do this, use a Phillips #0 screwdriver. Slide the optical drive out once the screw is removed.
    • Remove the screw that holds the optical drive in. To do this, use a Phillips #0 screwdriver. Slide the optical drive out once the screw is removed.
  5. Once the battery and optical drive are removed, remove the 11 screws that secure the palmrest.
    • Once the battery and optical drive are removed, remove the 11 screws that secure the palmrest.
    • This screw is hidden by a stick on cover. If lost, this is only cosmetic.
    • Not found on all models. On some models, there are screws in this area. If you see screws here, they must be removed.
    Caution: There are two additional screws on some models in the battery pack area on the far left and right of single screw shown in the picture above. Make sure to remove those screws as they are also securing the back of the palm rest to the computer.
    David May - 回复
    Good catch. I made the assumption all machines in the P series come apart the same way since multiple chassis in the same line are rare. What model machine do you have?
    Now that I’ve looked at my picture, I think I know what you’re talking about. I think you’re taking about the square areas that were never used on my machine?
    Nick -
    I added a marker to account for this. I meant to do it sooner, but it slipped past me. Let me know if I put the markers in the wrong location. I have not seen one of these, so I don’t know with 100% certainty.
    Nick -
  6. If you choose to reuse the original pads, stick them to the hinge caps to preserve the adhesive. Remove the hinge caps. To do this, remove the rubber pads. Use a Phillps #0 screwdriver. Remove the screws under the hinge caps. To do this, use a Phillps #0 screwdriver.
    • If you choose to reuse the original pads, stick them to the hinge caps to preserve the adhesive.
    • Remove the hinge caps. To do this, remove the rubber pads. Use a Phillps #0 screwdriver.
    • Remove the screws under the hinge caps. To do this, use a Phillps #0 screwdriver.
  7. The system used in the guide only came with one screw. If yours came with three, sort accordingly.
    • The system used in the guide only came with one screw. If yours came with three, sort accordingly.
    • With the palmrest screws removed, remove the screws under the optical drive. Use a Phillips #000 screwdriver.
    If I'm having troublds removing this screw what should I do? Using a Phillips #00
    mjsbak - 回复
    Try a Phillps #000 screwdriver. It worked for me with a #00, but #000 is a better fit when I revisited this.
    Nick -
    Mine has been worn out due to excessive use. What should I use to remove this screw?
    Ahmed Khan - 回复
  8. Do not remove the palmrest. The power button is still connected to the motherboard. If you are having trouble removing the palmrest, try using a guitar pick. Use a plastic tool to remove the palmrest. Once all 3 sides are loose, disconnect the keyboard and trackpad. Flip the black plastic tabs on the connectors up to remove the cables.
    • Do not remove the palmrest. The power button is still connected to the motherboard.
    • If you are having trouble removing the palmrest, try using a guitar pick.
    • Use a plastic tool to remove the palmrest. Once all 3 sides are loose, disconnect the keyboard and trackpad. Flip the black plastic tabs on the connectors up to remove the cables.
    • Once the keyboard and trackpad are disconnected, the palmrest can be moved forward. If needed, a pry tool can be used.
    >Step 8 Remove the palmrest
    lolwut
    Toynbee Idea - 回复
    Not sure if you’re being serious or sarcastic. If you’re serious, it says it in the line you quoted that from why it has to wait.
    Nick -
    This is very difficult to remove. I managed to get the hard drive removed without removing it completely. The corners would not come loose and I didn’t want to risk cracking the palmrest.
    Hollow Hills Ranch & Homestead - 回复
    The trick I’ve used on this HP chaissis is I will go over the back tabs with more attention then the rest, and then go over it again just to be sure.
    The alternative is to buy anything else that isn’t awful to service, but sadly if you own it you can’t do much about it.
    Nick -
  9. With the keyboard and trackpad disconnected, disconnect the power button. Flip the black tab up and remove the palmrest. With the keyboard and trackpad disconnected, disconnect the power button. Flip the black tab up and remove the palmrest. With the keyboard and trackpad disconnected, disconnect the power button. Flip the black tab up and remove the palmrest.
    • With the keyboard and trackpad disconnected, disconnect the power button. Flip the black tab up and remove the palmrest.
结论
3等其他人完成本指南。
Nick
于2009年11月10日注册
64,462 信誉积分
创作了41篇指南
团队
Master Techs Master Techs 的会员
Community
300 名成员
创作了991篇指南
一条评论
My power button is bad and my mouse track stopped working. I couldn't find a replacement for it. What can I do?
Trevor Gilbert - 回复
添加评论
浏览统计数据:
过去的24小时: 3
过去的7天: 18
过去的30天: 69
总计 4,083
