跳转到主内容
HP Pavilion 15-n210dx Hard Drive Replacement
你所需要的
  1. HP Pavilion 15-n210dx Hard Drive Replacement, Battery: 步骤 1 中的图像 1,1
    • Turn the laptop over.
  2. HP Pavilion 15-n210dx Hard Drive Replacement: 步骤 2 中的图像 1,3 HP Pavilion 15-n210dx Hard Drive Replacement: 步骤 2 中的图像 2,3 HP Pavilion 15-n210dx Hard Drive Replacement: 步骤 2 中的图像 3,3
    • Push the pins towards each other using your thumbs. The battery will pop out a little bit. Remove it using your hand.
  3. HP Pavilion 15-n210dx Hard Drive Replacement, Keyboard: 步骤 3 中的图像 1,1
    • Turn over the laptop and remove the single screw using a Tri-point Y0 screwdriver.
  4. HP Pavilion 15-n210dx Hard Drive Replacement: 步骤 4 中的图像 1,1
    • Open the laptop and use a spudger gently to get under the keyboard. Loosen the keyboard on all sides and then lift it up.
  5. HP Pavilion 15-n210dx Hard Drive Replacement: 步骤 5 中的图像 1,2 HP Pavilion 15-n210dx Hard Drive Replacement: 步骤 5 中的图像 2,2
    • Use the spudger to unhinge the fastener and remove the connector.
    • The keyboard should be completely detached from the computer now.
  6. HP Pavilion 15-n210dx Hard Drive Replacement, Hard Drive: 步骤 6 中的图像 1,1
    • Use the Tri-point Y0 screwdriver to remove all screws on the metal sheet, then remove the metal sheet.
  7. HP Pavilion 15-n210dx Hard Drive Replacement: 步骤 7 中的图像 1,2 HP Pavilion 15-n210dx Hard Drive Replacement: 步骤 7 中的图像 2,2
    在这个步骤中使用的工具:
    购买
    • Remove the two blue wire connectors using the reverse tweezers and lift up on the two wires to disconnect them.
  8. HP Pavilion 15-n210dx Hard Drive Replacement: 步骤 8 中的图像 1,1
    • Using the Phillips #0 screwdriver, remove the twelve (12) screws from the back panel.
  9. HP Pavilion 15-n210dx Hard Drive Replacement: 步骤 9 中的图像 1,2 HP Pavilion 15-n210dx Hard Drive Replacement: 步骤 9 中的图像 2,2
    • Remove the optic drive by pushing the edge with your thumbs to open it. Once open use two hands to remove it entirely.
  10. HP Pavilion 15-n210dx Hard Drive Replacement: 步骤 10 中的图像 1,1
    • Remove the screws that become exposed after removing the optic drive using a Phillips #0 screwdriver.
  11. HP Pavilion 15-n210dx Hard Drive Replacement: 步骤 11 中的图像 1,2 HP Pavilion 15-n210dx Hard Drive Replacement: 步骤 11 中的图像 2,2
    • Wedge the metal spudger between the black and silver plastic.
    • Slide the spudger along the edge of the laptop to help in ease of separation. Next use your hands to separate the black plastic from the silver plastic.
    • Avoid using the metal spudger unless it's for serious prying power. If used incorrectly, the metal spudger can damage the internal components of the device.
  12. HP Pavilion 15-n210dx Hard Drive Replacement: 步骤 12 中的图像 1,3 HP Pavilion 15-n210dx Hard Drive Replacement: 步骤 12 中的图像 2,3 HP Pavilion 15-n210dx Hard Drive Replacement: 步骤 12 中的图像 3,3
    • Remove the two connectors that are attached to the hard drive by lifting up and away from the connected port.
  13. HP Pavilion 15-n210dx Hard Drive Replacement: 步骤 13 中的图像 1,1
    • Remove the hard drive by lifting up on the back side of it.
结论
另外一个人完成了本指南。
Seth Shea
于10/25/21注册
222 声望
撰写一个指南
团队
UMass Dartmouth, Team 3-8, Sinclaire Fall 2021 UMass Dartmouth, Team 3-8, Sinclaire Fall 2021 的会员
UMASSD-SINCLAIRE-F21S3G8
4 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 28
总计 1,169
