跳转到主内容
HP Pavilion 15-d035dx Disk Drive Replacement
你所需要的
  1. HP Pavilion 15-d035dx Disk Drive Replacement, Battery: 步骤 1 中的图像 1,3 HP Pavilion 15-d035dx Disk Drive Replacement, Battery: 步骤 1 中的图像 2,3 HP Pavilion 15-d035dx Disk Drive Replacement, Battery: 步骤 1 中的图像 3,3
    • Switch the first lock, with the padlock icon, to the open position.
    • Then hold the second lock with the battery icon to the open position, while sliding out the battery pack.
  2. HP Pavilion 15-d035dx Disk Drive Replacement, Back Panel: 步骤 2 中的图像 1,1
    • Flip the laptop so that the back is facing upwards.
    • Locate the small screw on the back that holds the "L" shaped panel.
    • Using a 0 Phillip Screwdriver (4.0x4.7mm sized screw), unscrew the screw. It will not become detached from the panel but it will allow you to remove the back panel.
  3. HP Pavilion 15-d035dx Disk Drive Replacement: 步骤 3 中的图像 1,3 HP Pavilion 15-d035dx Disk Drive Replacement: 步骤 3 中的图像 2,3 HP Pavilion 15-d035dx Disk Drive Replacement: 步骤 3 中的图像 3,3
    • Using a plastic opening tool, pry the back panel from the computer, going all the way around it.
    • This will take a good amount of force and you will hear clicking noises as you snap each of the connections out of place.
  4. HP Pavilion 15-d035dx Disk Drive Replacement: 步骤 4 中的图像 1,1
    • Once the back panel is completely removed you will have access to the RAM and many other connections in the computer.
  5. HP Pavilion 15-d035dx Disk Drive Replacement, Disk Drive: 步骤 5 中的图像 1,1
    • Once you have removed the panel there is one screw (2.5x6mm) that will need to be unscrewed.
  6. HP Pavilion 15-d035dx Disk Drive Replacement: 步骤 6 中的图像 1,2 HP Pavilion 15-d035dx Disk Drive Replacement: 步骤 6 中的图像 2,2
    • After unscrewing the back screw for the disc drive another 14 screws (2.5x6.0mm) will need to be removed.
  7. HP Pavilion 15-d035dx Disk Drive Replacement: 步骤 7 中的图像 1,1
    • Now flip the computer back to right side up.
    • Using the plastic opening tool from iFixit to pry open the top half of laptop case. Take off the top half.
  8. HP Pavilion 15-d035dx Disk Drive Replacement: 步骤 8 中的图像 1,2 HP Pavilion 15-d035dx Disk Drive Replacement: 步骤 8 中的图像 2,2
    • Now seeing the inside of the laptop. Unscrew one more screw (2.0x3.0mm).
  9. HP Pavilion 15-d035dx Disk Drive Replacement: 步骤 9 中的图像 1,3 HP Pavilion 15-d035dx Disk Drive Replacement: 步骤 9 中的图像 2,3 HP Pavilion 15-d035dx Disk Drive Replacement: 步骤 9 中的图像 3,3
    • Now you should be able slide the disk drive out to the side.
    • Do not pull up on the disk drive. This could damage the plug ins and/or the case that help holds it all together.
结论
2等其他人完成本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 22
总计 1,136
