跳转到主内容
HP Pavilion 15-d017cl RAM Replacement
你所需要的
  1. HP Pavilion 15-d017cl RAM Replacement, Battery: 步骤 1 中的图像 1,3 HP Pavilion 15-d017cl RAM Replacement, Battery: 步骤 1 中的图像 2,3 HP Pavilion 15-d017cl RAM Replacement, Battery: 步骤 1 中的图像 3,3
    • To unlock the top left latch, place your finger on the black latch and slide toward the center of the computer.
    • You do not need to hold this latch when removing the battery.
  2. HP Pavilion 15-d017cl RAM Replacement: 步骤 2 中的图像 1,1
    • To unlock the top right latch, slide the black latch towards the center of the computer.
  3. HP Pavilion 15-d017cl RAM Replacement: 步骤 3 中的图像 1,1
    • The right latch is spring loaded, hold the latch towards the center of the computer.
    • To remove the battery, pull the battery bar away from the computer.
  4. HP Pavilion 15-d017cl RAM Replacement, RAM: 步骤 4 中的图像 1,2 HP Pavilion 15-d017cl RAM Replacement, RAM: 步骤 4 中的图像 2,2
    • Flip the laptop onto its back in order to have access to the back panel.
    • Using a Phillips #1 Screwdriver, unscrew the 5mm screw until the L-shaped panel feels like it can be removed.
  5. HP Pavilion 15-d017cl RAM Replacement: 步骤 5 中的图像 1,2 HP Pavilion 15-d017cl RAM Replacement: 步骤 5 中的图像 2,2
    • To remove the L-shaped panel, use the plastic opening tool to pry the panel from the back of the laptop. Make sure to move the tool the entire way around the panel.
    • This may require a good amount of strength to loosen the panel. As the opening tool is moving around the panel, clicking noises will be heard.
  6. HP Pavilion 15-d017cl RAM Replacement: 步骤 6 中的图像 1,3 HP Pavilion 15-d017cl RAM Replacement: 步骤 6 中的图像 2,3 HP Pavilion 15-d017cl RAM Replacement: 步骤 6 中的图像 3,3
    • Using a spudger, press down on the silver latches that are holding the RAM in place. The RAM looks like a blue rectangle and has a size of about 1 x 2 inches. A slight click will be heard, and the RAM should pop out. You can then pull it away from the laptop.
    • Now that the old RAM has been removed, the new RAM can be inserted back into the laptop by pressing it gently into the place where the old RAM was.
结论
4等其他人完成本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 10
总计 394
