跳转到主内容
HP Pavilion 15-cd040wm Back Cover Disassembly
你所需要的
  1. HP Pavilion 15-cd040wm Back Cover Disassembly, HP Pavilion 15-cd040wm Back Cover Disassembly: 步骤 1 中的图像 1,2 HP Pavilion 15-cd040wm Back Cover Disassembly, HP Pavilion 15-cd040wm Back Cover Disassembly: 步骤 1 中的图像 2,2
    • The first step is to remove the four rubber non-slip pads on the bottom of the laptop to expose screws hidden underneath them. Peel off each tab with your fingers.
    • If you have trouble gripping a tab, use a spudger to wedge it loose.
  2. HP Pavilion 15-cd040wm Back Cover Disassembly: 步骤 2 中的图像 1,2 HP Pavilion 15-cd040wm Back Cover Disassembly: 步骤 2 中的图像 2,2
    • 3x 10mm Phillips scews
    • 2x 5mm Phillips screws
    • 6x 6mm Phillips screws
    • Remove all screws using a size Phillips #0 screwdriver.
  3. HP Pavilion 15-cd040wm Back Cover Disassembly: 步骤 3 中的图像 1,3 HP Pavilion 15-cd040wm Back Cover Disassembly: 步骤 3 中的图像 2,3 HP Pavilion 15-cd040wm Back Cover Disassembly: 步骤 3 中的图像 3,3
    • Using the iFixit opening tool, carefully pry along the sides of the back cover.
    • After all of the edges of the back cover have been freed, use your opening tool to carefully unclip the tabs holding the back cover to the CD drive.
    • After everything is unclipped, you can safely remove the back cover from the rest of the device.
结论
3等其他人完成本指南。
Joe Krawczyk
于11/01/19注册
397 声望
创作了2篇指南
团队
UMass Dartmouth, Team S1-G1, Botvin Fall 2019 UMass Dartmouth, Team S1-G1, Botvin Fall 2019 的会员
UMASSD-BOTVIN-F19S1G1
4 名成员
创作了7篇指南
3条评论
It's not listed in here, but to remove the cd tray, just pull it straight out. The whole drive has a connector at the back.
Gage Cook - 回复
I’m trying to remove my backing and it seems to have a lip that goes over the edge, so I’m having a hard time getting it apart. Any suggestions?
Laura Green - 回复
Is this the same process for the HP Pavilion 15-cc055od? Do I pull out the disk drive as well? How would I remove the hard drive?
Baconface Smith - 回复
添加评论
浏览统计数据:
过去 24 小时: 8
过去 7 天: 36
过去 30 天: 136
总计 8,499
