跳转到主内容
HP Pavilion 15-cc023cl Battery Replacement
你所需要的
  1. HP Pavilion 15-cc023cl Battery Replacement, Battery: 步骤 1 中的图像 1,2 HP Pavilion 15-cc023cl Battery Replacement, Battery: 步骤 1 中的图像 2,2
    • Use a PH000 screwdriver to unscrew the eleven 4mm Phillip head screws located on the back panel.
  2. HP Pavilion 15-cc023cl Battery Replacement: 步骤 2 中的图像 1,1
    • Using the iFixit opening tool, pry open and remove the back cover of the laptop.
    • Be gentle when applying force to the cover.
  3. HP Pavilion 15-cc023cl Battery Replacement: 步骤 3 中的图像 1,2 HP Pavilion 15-cc023cl Battery Replacement: 步骤 3 中的图像 2,2
    • Use a PH000 screwdriver to unscrew the four 3.5mm Philips head screws located on the battery.
  4. HP Pavilion 15-cc023cl Battery Replacement: 步骤 4 中的图像 1,2 HP Pavilion 15-cc023cl Battery Replacement: 步骤 4 中的图像 2,2
    • Disconnect the port connecting the battery and the motherboard and then remove.
结论
7等其他人完成本指南。
2条评论
We have a CD player on our laptop. Do we have to do something special with it?
ellenfk91 - 回复
If you plan to replace it yeah, what do you even plan to replace? battery, no, harddrive, no, and im not sure about the other stuff.
Don't hurt the chickens -
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 35
总计 3,733
