简介
This guide will assist you in replacing the touchpad on your HP Pavilion 15-bk020wm device.
你所需要的
Remove the 4 computer feet. (Our device didn't have these; they can be taken off with a plastic spudger.)
Remove the two screw cover strips.
Remove the two screw cover plugs.
Unscrew all 12 screws (size: Phillips M2.5×7.0 ) from the bottom of the computer.
After taking the keyboard cover off of the device, flip it over and locate the purple and white cable.
Using the plastic opening tool, flip the ZIF connector open and detach the touchpad cable.
