跳转到主内容
HP Pavilion 15-bk020wm Hard Drive Replacement
你所需要的
  1. HP Pavilion 15-bk020wm Hard Drive Replacement, Keyboard Cover: 步骤 1 中的图像 1,2 HP Pavilion 15-bk020wm Hard Drive Replacement, Keyboard Cover: 步骤 1 中的图像 2,2
    • Before you begin, turn the laptop off and unplug it from the power source.
    • Remove the 4 computer feet. (Our device didn't have these; they can be taken off with a plastic spudger.)
    • Remove the two screw cover strips.
    • Remove the two screw cover plugs.
    • Unscrew all 12 screws (size: Phillips M2.5×7.0 ) from the bottom of the computer.
  2. HP Pavilion 15-bk020wm Hard Drive Replacement: 步骤 2 中的图像 1,3 HP Pavilion 15-bk020wm Hard Drive Replacement: 步骤 2 中的图像 2,3 HP Pavilion 15-bk020wm Hard Drive Replacement: 步骤 2 中的图像 3,3
    • Turn the computer over to the front.
    • Open the laptop.
    • Use a plastic pry tool to pry up the keyboard cover near the hinge on both the right and left side, and work your way towards the touchpad.
  3. HP Pavilion 15-bk020wm Hard Drive Replacement: 步骤 3 中的图像 1,1
    • Tilt the keyboard cover up slightly.
    • Do not fully remove the keyboard, as it is still attached to the laptop by some cables.
  4. HP Pavilion 15-bk020wm Hard Drive Replacement, Hard Drive: 步骤 4 中的图像 1,1
    • Remove the hard drive from the laptop.
    • Our device did not contain a hard drive.
结论
3等其他人完成本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 15
过去 30 天: 40
总计 17,053
