跳转到主内容
HP Pavilion 15-ba003ds Screen Replacement
你所需要的
  1. HP Pavilion 15-ba003ds Screen Replacement, Screen: 步骤 1 中的图像 1,3 HP Pavilion 15-ba003ds Screen Replacement, Screen: 步骤 1 中的图像 2,3 HP Pavilion 15-ba003ds Screen Replacement, Screen: 步骤 1 中的图像 3,3
    • Apply firm pressure and slide the metal spudger along the outside edges of the front panel screen.
    • When using the metal spudger, be careful not to press into the plastic panel too hard. It may damage internal cables or the panel.
  2. HP Pavilion 15-ba003ds Screen Replacement: 步骤 2 中的图像 1,3 HP Pavilion 15-ba003ds Screen Replacement: 步骤 2 中的图像 2,3 HP Pavilion 15-ba003ds Screen Replacement: 步骤 2 中的图像 3,3
    • Continue sliding the metal spudger to the bottom of the screen.
    • Don't pull on the frame outwards as this will put pressure on the panel and damage it.
  3. HP Pavilion 15-ba003ds Screen Replacement: 步骤 3 中的图像 1,3 HP Pavilion 15-ba003ds Screen Replacement: 步骤 3 中的图像 2,3 HP Pavilion 15-ba003ds Screen Replacement: 步骤 3 中的图像 3,3
    • Flip the laptop so the bottom is facing upwards.
    • Using the metal spudger, separate the plastic panel off the screen.
  4. HP Pavilion 15-ba003ds Screen Replacement: 步骤 4 中的图像 1,3 HP Pavilion 15-ba003ds Screen Replacement: 步骤 4 中的图像 2,3 HP Pavilion 15-ba003ds Screen Replacement: 步骤 4 中的图像 3,3
    • Once the panel is separated from the screen, gently pull it off and set it aside.
    • Remove two 6mm Phillips #00 screws from the bottom of the screen.
  5. HP Pavilion 15-ba003ds Screen Replacement: 步骤 5 中的图像 1,3 HP Pavilion 15-ba003ds Screen Replacement: 步骤 5 中的图像 2,3 HP Pavilion 15-ba003ds Screen Replacement: 步骤 5 中的图像 3,3
    • Remove two 6mm Phillips #00 screws from the top of the screen.
  6. HP Pavilion 15-ba003ds Screen Replacement: 步骤 6 中的图像 1,3 HP Pavilion 15-ba003ds Screen Replacement: 步骤 6 中的图像 2,3 HP Pavilion 15-ba003ds Screen Replacement: 步骤 6 中的图像 3,3
    • Flip the screen down.
    • Remove the tape from over the connector.
    • Pull out the connector using your fingers.
  7. HP Pavilion 15-ba003ds Screen Replacement: 步骤 7 中的图像 1,1
    • Lift the screen away from the laptop.
结论
Joseph Chia
于01/14/20注册
355 声望
创作了3篇指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 7
总计 248
