跳转到主内容
HP Pavilion 15-ba003ds Charging Port Replacement
你所需要的
  1. HP Pavilion 15-ba003ds Charging Port Replacement, Battery: 步骤 1 中的图像 1,2 HP Pavilion 15-ba003ds Charging Port Replacement, Battery: 步骤 1 中的图像 2,2
    • Unplug the AC adapter from the corresponding socket in the laptop.
    • Turn off your laptop before starting this procedure. Make sure it's not in sleep or hibernation mode.
    • Use your fingers to push the slider located just under the battery on either side to unlock the battery from the laptop.
    • Carefully slide the battery out of the laptop frame and place it somewhere safe.
  2. HP Pavilion 15-ba003ds Charging Port Replacement, Backplate: 步骤 2 中的图像 1,3 HP Pavilion 15-ba003ds Charging Port Replacement, Backplate: 步骤 2 中的图像 2,3 HP Pavilion 15-ba003ds Charging Port Replacement, Backplate: 步骤 2 中的图像 3,3
    • Use a Jimmy to pry off the black backplate.
  3. HP Pavilion 15-ba003ds Charging Port Replacement, Cooling Fan: 步骤 3 中的图像 1,2 HP Pavilion 15-ba003ds Charging Port Replacement, Cooling Fan: 步骤 3 中的图像 2,2
    • Remove three black 6mm Phillips #00 screws.
  4. HP Pavilion 15-ba003ds Charging Port Replacement: 步骤 4 中的图像 1,3 HP Pavilion 15-ba003ds Charging Port Replacement: 步骤 4 中的图像 2,3 HP Pavilion 15-ba003ds Charging Port Replacement: 步骤 4 中的图像 3,3
    • Unplug the white connector using your fingers or a spudger.
  5. HP Pavilion 15-ba003ds Charging Port Replacement: 步骤 5 中的图像 1,3 HP Pavilion 15-ba003ds Charging Port Replacement: 步骤 5 中的图像 2,3 HP Pavilion 15-ba003ds Charging Port Replacement: 步骤 5 中的图像 3,3
    • Pull out the fan by hand.
  6. HP Pavilion 15-ba003ds Charging Port Replacement, Charging Port: 步骤 6 中的图像 1,1
    • Use a spudger to disconnect the power cable from the motherboard.
  7. HP Pavilion 15-ba003ds Charging Port Replacement: 步骤 7 中的图像 1,3 HP Pavilion 15-ba003ds Charging Port Replacement: 步骤 7 中的图像 2,3 HP Pavilion 15-ba003ds Charging Port Replacement: 步骤 7 中的图像 3,3
    • Remove two 8mm Phillips #2 screws from the metal plate.
    • Use your hand to flip the metal plate so you can see the charging port fully.
  8. HP Pavilion 15-ba003ds Charging Port Replacement: 步骤 8 中的图像 1,2 HP Pavilion 15-ba003ds Charging Port Replacement: 步骤 8 中的图像 2,2
    • Use a spudger to pry off the charging port.
结论
LI XU
于01/14/20注册
334 声望
创作了2篇指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 33
总计 2,228
