跳转到主内容
HP Pavilion 15-b109wm WLAN Module Replacement
你所需要的
  1. HP Pavilion 15-b109wm WLAN Module Replacement, Battery: 步骤 1 中的图像 1,1
    • Power off the device and disconnect from any power source.
  2. HP Pavilion 15-b109wm WLAN Module Replacement: 步骤 2 中的图像 1,1
    • Turn the device upside down and ensure the back of the device is facing you.
  3. HP Pavilion 15-b109wm WLAN Module Replacement: 步骤 3 中的图像 1,3 HP Pavilion 15-b109wm WLAN Module Replacement: 步骤 3 中的图像 2,3 HP Pavilion 15-b109wm WLAN Module Replacement: 步骤 3 中的图像 3,3
    • Push both buttons towards one another simultaneously. The battery slightly pops out.
  4. HP Pavilion 15-b109wm WLAN Module Replacement: 步骤 4 中的图像 1,3 HP Pavilion 15-b109wm WLAN Module Replacement: 步骤 4 中的图像 2,3 HP Pavilion 15-b109wm WLAN Module Replacement: 步骤 4 中的图像 3,3
    • Pull out the battery from the device's battery slot.
  5. HP Pavilion 15-b109wm WLAN Module Replacement, Keyboard: 步骤 5 中的图像 1,2 HP Pavilion 15-b109wm WLAN Module Replacement, Keyboard: 步骤 5 中的图像 2,2
    • Use JIS #1 screwdriver to remove the eleven 6 mm screws.
  6. HP Pavilion 15-b109wm WLAN Module Replacement: 步骤 6 中的图像 1,1
    • Locate the two screw holes that allow access to removing the keyboard.
    • There is a keyboard sign beside both keyboard access holes.
  7. HP Pavilion 15-b109wm WLAN Module Replacement: 步骤 7 中的图像 1,1
    • Turn the device onto its side.
    • Using a heavy duty spudger, gently disengage the keyboard.
  8. HP Pavilion 15-b109wm WLAN Module Replacement: 步骤 8 中的图像 1,2 HP Pavilion 15-b109wm WLAN Module Replacement: 步骤 8 中的图像 2,2
    • Using a plastic opening tool, release the keyboard clips.
  9. HP Pavilion 15-b109wm WLAN Module Replacement: 步骤 9 中的图像 1,1
    • Tilt the keyboard to expose the Zero Insertion Force connector to which the keyboard cable is attached.
  10. HP Pavilion 15-b109wm WLAN Module Replacement: 步骤 10 中的图像 1,3 HP Pavilion 15-b109wm WLAN Module Replacement: 步骤 10 中的图像 2,3 HP Pavilion 15-b109wm WLAN Module Replacement: 步骤 10 中的图像 3,3
    • Disconnect the keyboard cable from the motherboard by detaching the Zero Insertion Force connector.
    • To detach the connector, release by lifting the black plastic tab up.
  11. HP Pavilion 15-b109wm WLAN Module Replacement, Fan: 步骤 11 中的图像 1,3 HP Pavilion 15-b109wm WLAN Module Replacement, Fan: 步骤 11 中的图像 2,3 HP Pavilion 15-b109wm WLAN Module Replacement, Fan: 步骤 11 中的图像 3,3
    • Using a JIS #1 screwdriver, remove the five 5mm screws.
    • Detach the power button cable.
    • Detach the touch pad cable.
  12. HP Pavilion 15-b109wm WLAN Module Replacement: 步骤 12 中的图像 1,3 HP Pavilion 15-b109wm WLAN Module Replacement: 步骤 12 中的图像 2,3 HP Pavilion 15-b109wm WLAN Module Replacement: 步骤 12 中的图像 3,3
    • Using a plastic opening tool, pry open the top cover.
    • Unscrew the two 5 mm screws using a JIS #1 screwdriver.
    • Gently, pull to detach the fan cable.
    • Be careful so you do not damage the motherboard.
  13. HP Pavilion 15-b109wm WLAN Module Replacement: 步骤 13 中的图像 1,1
    • Carefully remove the fan from its slot.
  14. HP Pavilion 15-b109wm WLAN Module Replacement, WLAN Module: 步骤 14 中的图像 1,2 HP Pavilion 15-b109wm WLAN Module Replacement, WLAN Module: 步骤 14 中的图像 2,2
    • Remove the 5 mm screw using a JIS #1 screwdriver.
  15. HP Pavilion 15-b109wm WLAN Module Replacement: 步骤 15 中的图像 1,2 HP Pavilion 15-b109wm WLAN Module Replacement: 步骤 15 中的图像 2,2
    • Detach the WLAN Module cords.
  16. HP Pavilion 15-b109wm WLAN Module Replacement: 步骤 16 中的图像 1,1
    • Remove the WLAN card and replace it with a new one.
结论
Stephen Gacioch
于10/26/18注册
437 声望
创作了3篇指南
团队
UMass Dartmouth, Team S2-G2, Peak Fall 2018 UMass Dartmouth, Team S2-G2, Peak Fall 2018 的会员
UMASSD-PEAK-F18S2G2
3 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 8
总计 209
