简介
This replacement guide will show how to replace the hard drive of an HP Pavilion 15-b109wm. This process might be needed in case the laptop has a faulty hard drive. This guide will take between 20-35 minutes, if done correctly. Remember to take your time and do the steps correctly and gently to avoid parts breakage.
For this guide you will need a heavy-duty spudger, a JIS driver set and an iFixtit opening tool. Some parts of this guide require some force to pop open, be careful not to brake or damage any parts when applying force.
你所需要的
Turn the device onto its side.
Using a heavy duty spudger, gently disengage the keyboard.
To reassemble your device, follow the instructions in reverse order.
2等其他人完成本指南。
