跳转到主内容
HP Pavilion 15-ay041wm RAM Replacement
你所需要的
  1. HP Pavilion 15-ay041wm RAM Replacement, Battery: 步骤 1 中的图像 1,2 HP Pavilion 15-ay041wm RAM Replacement, Battery: 步骤 1 中的图像 2,2
    • Place the laptop upside down.
  2. HP Pavilion 15-ay041wm RAM Replacement: 步骤 2 中的图像 1,2 HP Pavilion 15-ay041wm RAM Replacement: 步骤 2 中的图像 2,2
    • Find the battery lock latch on the top left corner.
    • Slide the latch to the right position.
  3. HP Pavilion 15-ay041wm RAM Replacement: 步骤 3 中的图像 1,3 HP Pavilion 15-ay041wm RAM Replacement: 步骤 3 中的图像 2,3 HP Pavilion 15-ay041wm RAM Replacement: 步骤 3 中的图像 3,3
    • Find the battery release latch on the top right corner.
    • Slide and hold the latch towards the left to cover the battery icon.
    • Carefully slide the battery outwards.
  4. HP Pavilion 15-ay041wm RAM Replacement, Disc Drive: 步骤 4 中的图像 1,1
    • Turn the laptop upside down with the base of the laptop facing you.
    • Remove the grippers positioned at the top right and top left of the laptop to access the two additional screws.
    • Use a 1.5mm Hex screwdriver to remove twelve 10mm screws.
  5. HP Pavilion 15-ay041wm RAM Replacement: 步骤 5 中的图像 1,3 HP Pavilion 15-ay041wm RAM Replacement: 步骤 5 中的图像 2,3 HP Pavilion 15-ay041wm RAM Replacement: 步骤 5 中的图像 3,3
    • Press the eject button.
    • Hold and carefully slide the disc drive out of the laptop.
  6. HP Pavilion 15-ay041wm RAM Replacement, Keyboard: 步骤 6 中的图像 1,3 HP Pavilion 15-ay041wm RAM Replacement, Keyboard: 步骤 6 中的图像 2,3 HP Pavilion 15-ay041wm RAM Replacement, Keyboard: 步骤 6 中的图像 3,3
    • Using the Jimmy, create a separation between the keyboard and bottom panel.
    • Slide around the body of the panel until the separation is big enough for you to use your fingers.
    • Separate the keyboard and bottom panel.
  7. HP Pavilion 15-ay041wm RAM Replacement, RAM: 步骤 7 中的图像 1,3 HP Pavilion 15-ay041wm RAM Replacement, RAM: 步骤 7 中的图像 2,3 HP Pavilion 15-ay041wm RAM Replacement, RAM: 步骤 7 中的图像 3,3
    • Orient the base of the laptop with the base facing away from you.
    • With you index finger and thumb, position your thumb underneath both latches on either side of the RAM and squeeze outwards.
    • Simultaneously, use your index finger to push the RAM sticks towards you.
    • The RAM stick will release and pop up and out.
  8. HP Pavilion 15-ay041wm RAM Replacement: 步骤 8 中的图像 1,2 HP Pavilion 15-ay041wm RAM Replacement: 步骤 8 中的图像 2,2
    • Repeat the same process for the top RAM stick.
    • The RAM stick will release and pop up. Pull the RAM stick out to remove it from the laptop.
结论
Carlton Makini
于01/30/20注册
195 声望
撰写一个指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 9
过去 30 天: 19
总计 725
