跳转到主内容
HP Pavilion 15-au123cl RAM Replacement
你所需要的
  1. HP Pavilion 15-au123cl RAM Replacement, Battery: 步骤 1 中的图像 1,1
    • Make sure the laptop is off and unplugged before starting.
    • Using the plastic opening tool, remove the top rubber feet on the back panel as it hides one of the screws we will be removing.
  2. HP Pavilion 15-au123cl RAM Replacement: 步骤 2 中的图像 1,2 HP Pavilion 15-au123cl RAM Replacement: 步骤 2 中的图像 2,2
    • Using a PH0 screwdriver, unscrew the ten 4.4mm Phillips head screws located on the back panel.
    Correction. Top two screen pivot screws are bigger than the 8, 4mm.
    Mitchell Culp II - 回复
  3. HP Pavilion 15-au123cl RAM Replacement: 步骤 3 中的图像 1,2 HP Pavilion 15-au123cl RAM Replacement: 步骤 3 中的图像 2,2
    • Using the plastic opening tool, remove the back cover of the laptop.
    • It is recommended that you start with a corner and run the tool throughout the edges of the cover.
    • Be sure not to bend the cover by applying too much force.
    What? I think you have have neglected to mention the DVD drawer. I believe it needs to be pulled out after removing the center screw and before removing the cover.
    Dan Enslow - 回复
    Yes, best to remove the drawer as recommended. Also there are 3 screws holding the battery, not 2.
    Lastly, pay careful attention to the orientation photo when removing the back.
    I did not have the plastic tool but used a small Teflon type kitchen spatula and it did the trick. Do not use a metal screw driver or other such tool.
    Edward Yandek - 回复
  4. HP Pavilion 15-au123cl RAM Replacement: 步骤 4 中的图像 1,2 HP Pavilion 15-au123cl RAM Replacement: 步骤 4 中的图像 2,2
    • Using a PH0 screwdriver, unscrew the two 3.8mm PH0 Phillips head screws that hold the battery in place.
    there is a third screw on bottom left of battery (in picture above)
    Paul Behrman - 回复
  5. HP Pavilion 15-au123cl RAM Replacement: 步骤 5 中的图像 1,3 HP Pavilion 15-au123cl RAM Replacement: 步骤 5 中的图像 2,3 HP Pavilion 15-au123cl RAM Replacement: 步骤 5 中的图像 3,3
    • Carefully disconnect the cable connecting the top of the battery and remove the battery.
  6. HP Pavilion 15-au123cl RAM Replacement, RAM: 步骤 6 中的图像 1,2 HP Pavilion 15-au123cl RAM Replacement, RAM: 步骤 6 中的图像 2,2
    • The RAM is located at the lower middle region of the motherboard.
    • Push down on the clips on both sides of the RAM stick evenly.
    • The RAM will become loose and move upward when the clips are pushed.
  7. HP Pavilion 15-au123cl RAM Replacement: 步骤 7 中的图像 1,1
    • Pull the RAM stick out of the motherboard.
    • The same steps work on both sticks of RAM.
结论
2等其他人完成本指南。
Mohammad Gardezi
于10/17/17注册
1,420 声望
创作了6篇指南
团队
USF Tampa, Team S13-G3, Cagle Fall 2017 USF Tampa, Team S13-G3, Cagle Fall 2017 的会员
USFT-CAGLE-F17S13G3
2 名成员
创作了6篇指南
一条评论
Thanks mate….your steps are helpful <3
Can you please guide on how to buy the RAM for this laptop…my current RAM is 4GB
Im planning to upgrade to 8GB
thanks
Gokul Prasad Rao - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 8
过去 30 天: 25
总计 1,379
