跳转到主内容
HP Pavilion 15-au123cl Fan Replacement
你所需要的
  1. HP Pavilion 15-au123cl Fan Replacement, Fan: 步骤 1 中的图像 1,2 HP Pavilion 15-au123cl Fan Replacement, Fan: 步骤 1 中的图像 2,2
    • Remove the ten screws from the back case with a Phillips #0 screwdriver.
    • Using a plastic opening tool, pry the CD drive from the computer.
    • Remove the back panel from the computer.
  2. HP Pavilion 15-au123cl Fan Replacement: 步骤 2 中的图像 1,1
    • Wearing an anti-static bracelet, disconnect the battery cable from the top of the battery with a spudger or plastic opening tool.
    • Remove the three screws from the fan assembly using a Phillips #0 screwdriver.
    • Gently disconnect the fan cable cable.
    • Remove the fan.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 3
总计 548
