简介
This guide will show you how to access your RAM and replace/upgrade the RAM. There are two slots allowing for an easy RAM expansion upgrade. The replacement of the current RAM is covered in this guide.
你所需要的
With the battery removed, remove both black plastic covers with a plastic opening tool. Unscrew both 7.5 mm screws from the tabs, using a PH1 screw driver. Using a plastic opening tool, pry off both covers.
Locate the RAM stick, will be next to hard drive. Unclip the two silver retainers on each side.
另外一个人完成了本指南。
