简介
This guide will show you how to access the cooling fan and replace it. The cooling fan is necessary to keep your laptop from overheating.
你所需要的
With the battery removed, remove both black plastic covers with a plastic opening tool. Unscrew both 7.5 mm screws from the tabs, using a PH1 screw driver. Using a plastic opening tool, pry off both covers.
Use a PH00 screw driver to remove the two 3.5 mm screws holding the fan in place.
2等其他人完成本指南。
