跳转到主内容
HP Pavilion 15-ab165us Motherboard Replacement
你所需要的
  1. HP Pavilion 15-ab165us Motherboard Replacement, Battery and Back Cover: 步骤 1 中的图像 1,2 HP Pavilion 15-ab165us Motherboard Replacement, Battery and Back Cover: 步骤 1 中的图像 2,2
    • Flip the computer over so that the bottom cover is facing you.
    • Slide the two locks to the "unlock" position and remove the battery.
  2. HP Pavilion 15-ab165us Motherboard Replacement: 步骤 2 中的图像 1,3 HP Pavilion 15-ab165us Motherboard Replacement: 步骤 2 中的图像 2,3 HP Pavilion 15-ab165us Motherboard Replacement: 步骤 2 中的图像 3,3
    • Remove the two 8mm screws underneath with a Phillips #1 screwdriver.
    • Use a plastic opening tool to remove the plastic feet.
  3. HP Pavilion 15-ab165us Motherboard Replacement: 步骤 3 中的图像 1,3 HP Pavilion 15-ab165us Motherboard Replacement: 步骤 3 中的图像 2,3 HP Pavilion 15-ab165us Motherboard Replacement: 步骤 3 中的图像 3,3
    • Remove the two plastic tabs with a metal spudger.
  4. HP Pavilion 15-ab165us Motherboard Replacement: 步骤 4 中的图像 1,1
    • Remove the sixteen 8mm screws that hold the bottom cover with a Phillips #1 screwdriver.
  5. HP Pavilion 15-ab165us Motherboard Replacement: 步骤 5 中的图像 1,1
    • Pull the Optical Drive out.
  6. HP Pavilion 15-ab165us Motherboard Replacement: 步骤 6 中的图像 1,1
    • Remove the 3mm screws that were hidden under the Optical Drive with a Phillips #0 screwdriver.
  7. HP Pavilion 15-ab165us Motherboard Replacement: 步骤 7 中的图像 1,2 HP Pavilion 15-ab165us Motherboard Replacement: 步骤 7 中的图像 2,2
    • Flip the computer back over.
    • Use a plastic opening tool to release the clips holding the keyboard section in place.
  8. HP Pavilion 15-ab165us Motherboard Replacement: 步骤 8 中的图像 1,1
    • Close the lid and pull the screen and keyboard section up and away from the disconnected bottom cover.
    • The hard drive is NOT screwed into place on the underside of the keyboard section.
  9. HP Pavilion 15-ab165us Motherboard Replacement, Motherboard: 步骤 9 中的图像 1,1
    • Locate the motherboard.
  10. HP Pavilion 15-ab165us Motherboard Replacement: 步骤 10 中的图像 1,2 HP Pavilion 15-ab165us Motherboard Replacement: 步骤 10 中的图像 2,2
    • Disconnect the wire connected to the Wifi card.
  11. HP Pavilion 15-ab165us Motherboard Replacement: 步骤 11 中的图像 1,1
    • Disconnect the speakers.
  12. HP Pavilion 15-ab165us Motherboard Replacement: 步骤 12 中的图像 1,3 HP Pavilion 15-ab165us Motherboard Replacement: 步骤 12 中的图像 2,3 HP Pavilion 15-ab165us Motherboard Replacement: 步骤 12 中的图像 3,3
    • Unlock and disconnect cables attached to the motherboard that connect to the display.
  13. HP Pavilion 15-ab165us Motherboard Replacement: 步骤 13 中的图像 1,2 HP Pavilion 15-ab165us Motherboard Replacement: 步骤 13 中的图像 2,2
    • Unlock and remove the cable connected to the optical drive.
  14. HP Pavilion 15-ab165us Motherboard Replacement: 步骤 14 中的图像 1,2 HP Pavilion 15-ab165us Motherboard Replacement: 步骤 14 中的图像 2,2
    • Unlock and remove the cable that connects to the hard drive.
  15. HP Pavilion 15-ab165us Motherboard Replacement: 步骤 15 中的图像 1,3 HP Pavilion 15-ab165us Motherboard Replacement: 步骤 15 中的图像 2,3 HP Pavilion 15-ab165us Motherboard Replacement: 步骤 15 中的图像 3,3
    • Unlock and remove the cables connected to the keyboard.
  16. HP Pavilion 15-ab165us Motherboard Replacement: 步骤 16 中的图像 1,1
    • Remove the 4mm screws holding the motherboard in place with a Phillips #1 screwdriver.
  17. HP Pavilion 15-ab165us Motherboard Replacement: 步骤 17 中的图像 1,1
  18. HP Pavilion 15-ab165us Motherboard Replacement: 步骤 18 中的图像 1,2 HP Pavilion 15-ab165us Motherboard Replacement: 步骤 18 中的图像 2,2
    • Disconnect the fan pins.
    • Lift up to remove the fan.
  19. HP Pavilion 15-ab165us Motherboard Replacement: 步骤 19 中的图像 1,1
    • Release motherboard from the clip at the base of the hard drive.
  20. HP Pavilion 15-ab165us Motherboard Replacement: 步骤 20 中的图像 1,2 HP Pavilion 15-ab165us Motherboard Replacement: 步骤 20 中的图像 2,2
    • Lift the motherboard up and flip it around to reveal the cable connected on the underside.
  21. HP Pavilion 15-ab165us Motherboard Replacement: 步骤 21 中的图像 1,2 HP Pavilion 15-ab165us Motherboard Replacement: 步骤 21 中的图像 2,2
    • Unlock and disconnect the cable connected to the underside of the motherboard.
    • Pull the motherboard out of the chassis.
结论
3等其他人完成本指南。
Dillon Hubble
于10/20/17注册
653 声望
创作了3篇指南
团队
UW Tacoma, Team S1-G2, Rose Fall 2017 UW Tacoma, Team S1-G2, Rose Fall 2017 的会员
UWT-ROSE-F17S1G2
5 名成员
创作了14篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 14
总计 1,500
