跳转到主内容
HP Pavilion 15-ab165us Hard Drive Replacement
你所需要的
  1. HP Pavilion 15-ab165us Hard Drive Replacement, Battery and Back Cover: 步骤 1 中的图像 1,2 HP Pavilion 15-ab165us Hard Drive Replacement, Battery and Back Cover: 步骤 1 中的图像 2,2
    • Flip the computer over so that the bottom cover is facing you.
    • Slide the two locks to the "unlock" position and remove the battery.
  2. HP Pavilion 15-ab165us Hard Drive Replacement: 步骤 2 中的图像 1,3 HP Pavilion 15-ab165us Hard Drive Replacement: 步骤 2 中的图像 2,3 HP Pavilion 15-ab165us Hard Drive Replacement: 步骤 2 中的图像 3,3
    • Remove the two 8mm screws underneath with a Phillips #1 screwdriver.
    • Use a plastic opening tool to remove the plastic feet.
  3. HP Pavilion 15-ab165us Hard Drive Replacement: 步骤 3 中的图像 1,3 HP Pavilion 15-ab165us Hard Drive Replacement: 步骤 3 中的图像 2,3 HP Pavilion 15-ab165us Hard Drive Replacement: 步骤 3 中的图像 3,3
    • Remove the two plastic tabs with a metal spudger.
  4. HP Pavilion 15-ab165us Hard Drive Replacement: 步骤 4 中的图像 1,1
    • Remove the sixteen 8mm screws that hold the bottom cover with a Phillips #1 screwdriver.
  5. HP Pavilion 15-ab165us Hard Drive Replacement: 步骤 5 中的图像 1,1
    • Pull the Optical Drive out.
  6. HP Pavilion 15-ab165us Hard Drive Replacement: 步骤 6 中的图像 1,1
    • Remove the 3mm screws that were hidden under the Optical Drive with a Phillips #0 screwdriver.
  7. HP Pavilion 15-ab165us Hard Drive Replacement: 步骤 7 中的图像 1,2 HP Pavilion 15-ab165us Hard Drive Replacement: 步骤 7 中的图像 2,2
    • Flip the computer back over.
    • Use a plastic opening tool to release the clips holding the keyboard section in place.
  8. HP Pavilion 15-ab165us Hard Drive Replacement: 步骤 8 中的图像 1,1
    • Close the lid and pull the screen and keyboard section up and away from the disconnected bottom cover.
    • The hard drive is NOT screwed into place on the underside of the keyboard section.
  9. HP Pavilion 15-ab165us Hard Drive Replacement, Hard Drive: 步骤 9 中的图像 1,1
    • Locate the ribbon cable connecting the hard drive to the motherboard.
  10. HP Pavilion 15-ab165us Hard Drive Replacement: 步骤 10 中的图像 1,1
    • On the motherboard, lift the white tab up to release the ribbon cable.
  11. HP Pavilion 15-ab165us Hard Drive Replacement: 步骤 11 中的图像 1,1
    • Pull the blue tab up and out from the motherboard to disconnect the ribbon cable.
  12. HP Pavilion 15-ab165us Hard Drive Replacement: 步骤 12 中的图像 1,1
    • Pull the hard drive out of the enclosure.
结论
4等其他人完成本指南。
Preston Palmer
于11/01/17注册
218 声望
撰写一个指南
团队
UW Tacoma, Team S1-G2, Rose Fall 2017 UW Tacoma, Team S1-G2, Rose Fall 2017 的会员
UWT-ROSE-F17S1G2
5 名成员
创作了14篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 12
过去 30 天: 41
总计 2,468
