跳转到主内容
HP Pavilion 15-AB153NR Bottom Case Cover Replacement
你所需要的
  1. HP Pavilion 15-AB153NR Bottom Case Cover  Replacement, Battery: 步骤 1 中的图像 1,1
    • Ensure computer is turned off and unplugged.
    • Slide the battery lock latch on the left to unlock. Slide from left to right to unlock.
  2. HP Pavilion 15-AB153NR Bottom Case Cover  Replacement: 步骤 2 中的图像 1,2 HP Pavilion 15-AB153NR Bottom Case Cover  Replacement: 步骤 2 中的图像 2,2
    • Slide the battery release latch on the right with continuous force from right to left.
    • Once battery pops, you may release latch.
  3. HP Pavilion 15-AB153NR Bottom Case Cover  Replacement: 步骤 3 中的图像 1,2 HP Pavilion 15-AB153NR Bottom Case Cover  Replacement: 步骤 3 中的图像 2,2
    • Grab the battery, rotating upwards and away from you. This will remove the battery.
  4. HP Pavilion 15-AB153NR Bottom Case Cover  Replacement, CD/DVD Drive: 步骤 4 中的图像 1,1
    • Make sure computer is powered off and unplugged.
    • Flip computer over so that the bottom is facing the ceiling and the hinges are farthest from you.
  5. HP Pavilion 15-AB153NR Bottom Case Cover  Replacement: 步骤 5 中的图像 1,1
    • Using the Phillips #000 screwdriver, remove the 7 mm screw on the middle right.
    • There is an icon that looks like a CD stamped into the back panel near this screw.
  6. HP Pavilion 15-AB153NR Bottom Case Cover  Replacement: 步骤 6 中的图像 1,2 HP Pavilion 15-AB153NR Bottom Case Cover  Replacement: 步骤 6 中的图像 2,2
    • Slide the drive out from the right side of the device.
  7. HP Pavilion 15-AB153NR Bottom Case Cover  Replacement, Bottom Case Cover: 步骤 7 中的图像 1,1
    • Using the Phillips #1 screwdriver, remove the two 12mm screws located on the hinge covers.
  8. HP Pavilion 15-AB153NR Bottom Case Cover  Replacement: 步骤 8 中的图像 1,2 HP Pavilion 15-AB153NR Bottom Case Cover  Replacement: 步骤 8 中的图像 2,2
    • Lift the corner covers off of the computer using a prying tool.
  9. HP Pavilion 15-AB153NR Bottom Case Cover  Replacement: 步骤 9 中的图像 1,1
    • Remove the six 6.5mm screws using a Phillips #1 screwdriver that are located near the top of the laptop.
  10. HP Pavilion 15-AB153NR Bottom Case Cover  Replacement: 步骤 10 中的图像 1,1
    • Remove the remaining seven 6.5mm screws using a Phillips #1 screwdriver that are securing the back cover.
  11. HP Pavilion 15-AB153NR Bottom Case Cover  Replacement: 步骤 11 中的图像 1,1
    • Use the Phillips #0 screwdriver to remove the two 2mm screws.
  12. HP Pavilion 15-AB153NR Bottom Case Cover  Replacement: 步骤 12 中的图像 1,3 HP Pavilion 15-AB153NR Bottom Case Cover  Replacement: 步骤 12 中的图像 2,3 HP Pavilion 15-AB153NR Bottom Case Cover  Replacement: 步骤 12 中的图像 3,3
    • Use prying tools to pry the covers off of the screwholes.
    • Using the Phillips #1 screwdriver, remove the two 6.5mm screws.
  13. HP Pavilion 15-AB153NR Bottom Case Cover  Replacement: 步骤 13 中的图像 1,1
    • Be mindful of sharp edges on computer while using prying tools.
    • Flip computer over and open so that the screen is facing you.
    • Starting at the bottom right corner, insert the prying tool and lift upwards to loosen the back panel.
    • Continue down all sides and corners of the device.
  14. HP Pavilion 15-AB153NR Bottom Case Cover  Replacement: 步骤 14 中的图像 1,2 HP Pavilion 15-AB153NR Bottom Case Cover  Replacement: 步骤 14 中的图像 2,2
    • Flip laptop back over so that the bottom is facing up
    • After all sides are loosened, remove the back panel from the device.
结论
2等其他人完成本指南。
Nicole Vachon
于03/21/19注册
926 声望
创作了7篇指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 16
总计 1,131
