简介
This replacement will require the use of prying tools. This can be competed in a moderate amount of time with little time. You will need a clear work surface. Replacing the back panel solves vanity issues.
你所需要的
Slide the battery lock latch on the left to unlock. Slide from left to right to unlock.
Flip computer over so that the bottom is facing the ceiling and the hinges are farthest from you.
Using the Phillips #1 screwdriver, remove the two 12mm screws located on the hinge covers.
2等其他人完成本指南。
